6.0 Coolant filter or no coolant filter
If you don't want to install a coolant filter, then spend the money on a scangauge so you can watch the ECT/EOT spread.
It's kinda like people spending money on oil analysis - why would they do that if the engine is running fine? Because it's preventative, a small cost now to avoid a possible big cost later. All you have to do is decide what "possible" might mean, then spend (or save) accordingly. As you might have guessed, I have a coolant filter. And a scangauge.
I'm one of those who installed the filter at 40K miles, changed it three times in 65k miles and have very little to no debris in the system.
A good indicator is to drain the coolant out of the expansion tank and look what is left on the bottom. If you are clean then you are probably good to go. If there is a brown or other colored residue in the bottom of the tank then you may have the start toward cooler issues. Just food for thought.
DSMMH
Schlominator
02-11-2013 10:25 PM
builttoughf350
05-15-2010 07:30 PM
