Thought I heard that you can't run it in the newer diesels (post 6.0) due to the emissions controls. Something about injecting unburned bio into the exhaust causing the Catalitic to plug. Might be wrong, hope someone else chimes in...
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
From what I've read it's not that it plugs the filter, but the fumes pass through the crankcase during regeneration and the bio gets absorbed into the oil. #2 does the same thing, but the boiling point of #2 is low enough that it boils out during normal operation. Bio has a boiling point much higher, so it doesn't evaporate and adds up over time, diluting your oil. How big of an issue it is is debatable, but remove the DPF (delete pipe and a tuner) and you eliminate the problem.
