1972 F250 "Big 3" upgrade
I trying to figure out how to do the "Big 3" upgrade to my 1972 ford f250. The problem i am having is that the positive wire doesnt go directly to the alternator, it goes to the started solenoid then 3 small wires go from that to the alternator. Is there a way to go directly from the battery to the alternator, or turn those 3 wires into one?
Run a #1 cable from the battery to the solenoid, then a #6 or #4 from the alternator to the same post of the solenoid. To make it worthwhile, run a #1 from the other post of the solenoid to the starter.
With the relatively low output of the stock alternator, there isn't much point to running a larger cable to it. You should also put a 100amp megafuse on that connection. The stock cable is actually a fusible link, which works the same as a fuse.
ok, should i leave the other two wires going to the alternator in tact, or should will that one work? im not sure why there is three, i heard something about the alternator charges the headlights or something, and it appears that two of the wires might be coming from the headlight/horn area. I cant tell because all my wires are taped together.
Jeremy Huston
06-16-2015 02:50 PM
jasindude1
25
09-19-2014 01:01 AM
Ratherbeefishin
20
11-09-2013 03:51 PM
oldesailor
05-08-2004 10:11 PM
