how to tighten shift linkage? - Ford Truck Enthusiasts Forums
Old 02-21-2012, 11:53 PM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
well, i had a bad habit, resting my hand on the shifter... it is soooo sloppy now,and it wont even go into 1st now.. we manually put it into 1st, so the trans is not the problem... do i have to put a new cable in? or something in the column to tighten.....??? searched, couldnt find anything.
in other news, finally replaced my steady bearing.. a lot LESS road noise now.! used a press to get it off.
to do:
-shift linkage
-trans fluid flush& filter
- front diff fluid change
-new front calipers
-new flex plate
-front steering stablizer
Old 02-22-2012, 12:06 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
There are a few things you can check before replacing first would be the torx screws, they are pretty common to loosen up.
You can also adjust the linkage
PRND2L Linkage Adjustment
And to adjust the pointer there is a thumbwheel to adjust
Pointer Adjustment
Then the actual shifter tube would need replacing if these could not correct your issue.
Old 02-22-2012, 12:23 AM
bluescrew's Avatar
you are AWESOME!!! thank you sir!
Old 02-22-2012, 12:27 AM
BigAlsPSD's Avatar
Learned about all of it on this forum, so this forum is AWESOME. Just passing along the information. I bet your issue is the torx screws though, mine use to loosen up about once a month until I medium strength loctited them in place.
Old 02-22-2012, 12:32 AM
bluescrew's Avatar
are those torx screws inside the cab? underneath the panel under the steering wheel? really hard to tell
Old 02-22-2012, 12:35 AM
BigAlsPSD's Avatar
Yes if you are laying in the floor top of your head against the pedals looking basically straight up they are there, tough to find, but once you know they are there, you can find them every time.
Old 02-22-2012, 12:38 AM
bluescrew's Avatar
just found the screws. HOT DAMN YOURE GOOD!!! fixed the problem!!! thank you sir!
Old 02-22-2012, 12:40 AM
BigAlsPSD's Avatar
Glad to hear it was simple.
Old 02-22-2012, 01:45 AM
VRC9170's Avatar
VRC9170 VRC9170 is offline
VRC9170 is gaining momentum as a positive member of FTE.VRC9170 is gaining momentum as a positive member of FTE.
Sometimes I have to slightly move the shift lever to start the truck. Would tightening these screws possibly fix that too?
Old 02-22-2012, 01:47 AM
BigAlsPSD's Avatar
Simplest possibility there is.
Old 02-22-2012, 01:50 AM
VRC9170's Avatar
I will try it tomorrow. Where would we all be without FTE?
Old 02-22-2012, 01:52 AM
VRC9170's Avatar
BigAl, You must be up late tonight.
Old 02-22-2012, 02:44 AM
BigAlsPSD's Avatar
I work nights. Then volunteer on call til around 6am
Old 02-22-2012, 02:52 AM
VRC9170's Avatar
I never have to work in the dark.
Old 02-22-2012, 03:00 AM
BigAlsPSD's Avatar
All VFR or just the perks.
1989 AOD Trans won't shift out of drive?? jdhudall Clutch, Transmission, Differential, Axle & Transfer Case 3 05-20-2015 01:58 AM
98 expo AWD trans or transfer problem. Need trans pressure specs R&J Whitetails Explorer, Sport Trac, Mountaineer & Aviator 8 11-30-2014 11:01 PM
Trans shift linkage loose bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 3 05-21-2011 12:26 AM
C6 skipping 2nd gear? racinmike88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 10-18-2010 11:55 PM
NP435 Grinding truckn 1978 - 1996 Big Bronco 2 08-20-2002 03:03 PM
Tags
1997, 73, 97, automatic, expedition, ford, images, linkage, shift, shifter, start, taurus, tighten, truck, trucks, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
