progress on my 56 frame.....Lexus IFS - Page 2 - Ford Truck Enthusiasts Forums
Old 02-24-2012, 07:09 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
John, a build thread would be great!
Old 02-24-2012, 07:29 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
From WikiLeaks
The SC 400 débuted on June 1, 1991 in the United States as a 1992 model. The SC 400's 4.0 L V8 1UZ-FE, the same engine as used in the LS 400,
I should have asked before : Does posting this info make me a darksider
Old 02-24-2012, 08:38 PM
epp's Avatar
epp epp is offline
epp is gaining momentum as a positive member of FTE.
lol welcome to the Darkside! Looks like a sweet install
Old 02-24-2012, 10:07 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Originally Posted by 4tl8ford View Post
From WikiLeaks
No sir, but for a minute, I thought you were NumberDummy!
Old 02-24-2012, 10:55 PM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
Im kinda used to being kept in the dark, so its an easy fit for me LOL
Just as i thought, they came out around the same time as here.....should be fairly easy to find. John
Old 02-24-2012, 10:58 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Please post more pix of that install and info like year suspension you used. Doing research on google I get conflicting info, some sites say the SC400 uses McPherson struts, some say IFS??? What is the hub bolt pattern and tread width?
Old 02-24-2012, 11:00 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
My favorite SC400 version is the "DONK". I've seen a few like these around here, but in different colors.
Old 02-24-2012, 11:17 PM
lexcoe's Avatar
Ax, the unit i am using is a 92/3, they are Ford bolt pattern but using metric studs.
The SC400 i parted out used a airbag setup that looks similiar to a McPherson strut i guess, but as you can see its a normal upper and lower a arm setup.
It would be VERY easy to setup using a coilover, however in my case i am going to use a bellcrank setup to run inboard airbags and shocks.
Any specific areas you want to see? I can take some more pics if you like.....
John
Old 02-25-2012, 01:33 AM
Wow, I did an image search on google. Thats actually a good looking car!
Old 02-25-2012, 12:49 PM
POS-F500's Avatar
POS-F500 POS-F500 is offline
POS-F500 is gaining momentum as a positive member of FTE.POS-F500 is gaining momentum as a positive member of FTE.
You sir, are a genius. And yes, a build/install thread would be much appreciated. That looks incredible. I want to know more about the steering hookup. Trackwidth?
Now grind that thing down and polish that aluminum!
P.S., yes, 1991 era Lexus's.. (Lexi?) are DIRT cheap. Lower than scrap value if the engine's toast, etc.
Old 02-25-2012, 03:57 PM
AXracer's Avatar
Lexus's aren't cheap around here, ~ 1500. for a project car, 4K for decent good runner.
Tread width is virtually the same and gross weight is close.
Old 02-25-2012, 09:50 PM
lexcoe's Avatar
I will fit the rack and take some more pics, had a bit of a tidy up in my shed so i feel better now. LOL
Ax, most people most likely wont run the Lexus V8 as i plan to do, so the prices for donar cars to get the suspension out of will be pretty low.
The 4 litre V8 is a nice engine and a pretty common swap into all sorts of vehicles in Australia, including hot rods and classic trucks. Wire harnesses are readily available too.
But i for one think the front suspension is a nice fit into an effie, dont think its been done before but i dont mind being a test pilot so to speak. LOL
John
  #28
Old 02-27-2012, 03:23 AM
lexcoe's Avatar
took a pic with the rack mounted, but note the clamp is not fitted to the L/H red urethane mount.
Also used the Lexus hardware to mount the sway bar, couldnt be easier.
Heres a link to the pic, John
http://www.ford-trucks.com/forums/pi...ictureid=94080
  #29
Old 02-27-2012, 01:06 PM
AXracer's Avatar
I'm fascinated by this install! What is the ride (frame) height like compared to stock when the lower A frames are parallel to the ground? What is the outside frame width of your COE? Could you post a picture from the front shot at frame level and from the side at the same height without the wheel? Thanks in advance.
  #30
Old 02-27-2012, 07:31 PM
lexcoe's Avatar
I will try and get some time today for a few pics. John
volare front suspension lexcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 12-22-2016 09:55 PM
new guy with 55 f100 with ???'s zmanh2o 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-30-2016 02:02 PM
Lexus IFS Question SummerBreeze2 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-23-2015 08:50 PM
56 frame lexcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-25-2012 06:25 AM
Front crossmember measurement please.. lexcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-14-2012 05:10 PM
Tags
1937, 373, 56, 88, coe, ford, frame, ifs, lexus, navigation, navigator, panel, powered, system, truck, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
