Interior lights won't shut off - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-21-2012, 06:14 PM
Natural Gas Natural Gas is offline
Natural Gas is starting off with a positive reputation.
I have a 2001 F350 Lariat V10. When I get in and close the door the door ajar light on dash is on and interio lights stay on till I drive a bit then I'll hear a click in dash lights go off but the door ajar light stays on. When I park shut off truck and open door interior lights come on as they should, but when I close and lock doors the lights stay on and will drain by battery. Right now if I have to use my truck I disconnect negative terminal on battery. Before I go to Stealership anyone know what this would be? Relay maybe I'm hoping? Thanks in advance for any replys. Jim
Old 02-21-2012, 07:11 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Natural, get a can of wd-40 and spray the latch (where the latch hits the post inside the door)shut the door repeat, repeat, repeat, repeat, you get the idea. The switch on the strike mechanism in the door is sticking, usually several baths in wd-40 and opening and slamming the door will break the switch loose and you will be good to go. While you have the wd out you might go ahead and do the other doors too!!
Old 02-21-2012, 07:28 PM
Rongold's Avatar
Rongold Rongold is offline
Rongold is gaining momentum as a positive member of FTE.
Sticking Switch
The switch is located at the top of the latch, so spray into the latch facing upward.
RON
Old 02-22-2012, 05:19 AM
Thank you Guys. I'll Do that. I don't drive the truck that often. 2001 with 40k miles. That's got to be it. Nat
Old 02-22-2012, 05:25 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I think the lights and door warning have separate switches. My light quit working and not liking them to stay on during day time, I replaced faulty relay with wires and switch on the dashboard. The door ajar warning still works.
I tried WD40 trick before and it worked for few months before it start having problems again.
Old 02-22-2012, 04:43 PM
I sprayed and worked the latches for awhile. Didn't help. Is there a relay that could be bad? If so location? I really don't want to go to dealer for this.
Old 02-22-2012, 09:22 PM
Kajtek1's Avatar
Per my recollection the light relay is in upper left corner on the relay panel under the dash. It is easy to spot as this is relay with 3 connectors only. I put spades in the holes that connect the power to the light and run wires to the dash switch.
Old 02-23-2012, 05:02 AM
Thanks, I pull that and go from there. Nat
Old 11-06-2012, 04:30 PM
mshaneh mshaneh is offline
mshaneh is starting off with a positive reputation.
Thanks for the post regarding the latches. I was having the same issue with my interior lights coming on and off; especially when driving. Shooting wd-40 up inside using the "straw" solved the problem for me.
Old 11-06-2012, 05:55 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Quote:
Some times you have to spray them pretty good before they'll work.
Old 02-15-2013, 07:26 PM
RuthieB75 RuthieB75 is offline
RuthieB75 is starting off with a positive reputation.
interior lights
That worked great and right away thanks guys. I love it when its a quick, easy... cheep fix like that! lol
98 ford expediton ajar and interior lights stay on Ford-Muscle 1997-2006 Expedition & Navigator 13 02-13-2016 06:09 PM
Door ajar light stays on? Chargerkid Excursion - King of SUVs 12 01-08-2016 10:09 AM
2003 F350 Lariet Dome lights wont turn off... Alta 1999 to 2016 Super Duty 6 05-30-2015 06:16 PM
95 Mercury Villager Interior Lights Stay On. danlee Electrical Systems/Wiring 2 01-07-2010 06:23 PM
Interior/running board lights will not turn off vgibbs Excursion - King of SUVs 8 07-04-2009 06:43 PM
Tags
01, 2004, cut, dome, duty, escape, excursion, expedition, flex, ford, interior, lights, super, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
