f700 fuel solenoid problem - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 02-21-2012, 04:47 PM
TreesnFords TreesnFords is offline
TreesnFords is starting off with a positive reputation.
My F700 shuts off sporatically while driving and now is stuck in my driveway. I replaced the fuel solenoid already and that was not it. When I hold the solenoid down manually it will start and run no problem. Also, I am not getting any power to the plug on the solenoid. I think it is either the ignition switch on the column or a relay somewhere. Does anyone have a wiring diagram for the solenoid/ignition? or any ideas of where to go next.
Old 02-21-2012, 06:23 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
I dont think they even had a relay in the circuit. If it quits running randomly, then it's likely got a bad connection somewhere.
Old 02-22-2012, 01:42 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
what year is this truck? which engine?
Old 02-22-2012, 05:00 AM
Its a 1987 with the 6.6. I did look high and low for a relay, maybe thats why I cant find it.
Old 02-22-2012, 08:05 AM
nevrenufhp's Avatar
If you want to throw a part at it for sake of reliability, go with an ign switch. If that's not it, then at least you have peace of mind. You could run a new 12 or 14ga wire from the ign switch or fuse panel for testing purposes.
Old 02-22-2012, 08:42 AM
went to order a new switch through ford. they told me it may be the relay. come to find out there is one mounted up under the glove box, of all places. took it out and it looks like it may be burnt on the power terminal. i will have a new one tomorrow. its not an exact replacement (discontinued) but the new one has instructinons on how to wire up correctly. we will see. THANKS FOR YOUR HELP GUYS! i will let you know how i make out!
Russ
Old 02-25-2012, 04:26 PM
ralph123 ralph123 is offline
ralph123 is starting off with a positive reputation.
Quote:
Russ
I may have a few ideas if that don't work
Old 02-25-2012, 07:05 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
If it is like the F700 I helped a fellow with there are two really weird looking relays on the top of the firewall. One is a start relay, the other is a run relay. One is powered when ever the key is on, the other is powered while cranking. The fuel solenoid works the lever on the side of the injection pump. It has three positions, off, run and start. What I did was use a Bosch relay in a fog lamp kit to replace the bad run relay on the truck, that was 5 or 6 years ago.
Old 02-26-2012, 06:44 PM
Well, I put the new relay in that Ford sold me. It started right up with no troubles. I am taking the truck out tomorrow for a 60 mile run. I will keep everyone posted. Thanks for all your advice.
Russ
Old 02-26-2012, 06:56 PM
nevrenufhp's Avatar
Now that it runs, you can adjust the fuel screw and timing.
Old 03-03-2012, 05:50 AM
Many miles on it since the relay change. That was definately the problem. I would like to attempt to adjust the pump for some more power, she is very sluggish! I did notice that one of the bolts on the exhaust side of the turbocharger is missing and I should fix this before I start messing with the timing and pump. What do you think?
Old 03-03-2012, 09:59 AM
nevrenufhp's Avatar
Bosch MW pump fuel rate adjustment (DT360, DT466, Ford 6.6 & 7.8, and a few others) - YouTube
That's the fuel screw, and how easy it is to do.
Yes, you should replace the bolt, just in case exhaust starts leaking out from added fuel. Not a life & death thing to do, though. You can certainly do the screw & timing. The timing is almost identical to the DT466 in my other video. The difference being, you find your timing marks(about 13-15*), loosen up the 4 retaining bolts on the gear, then rotate the engine back to your desired advance(17-19*), then tighten it all back up. The 7.8's actually have a peep window like the DT466 to see the timing marks, the 6.6 doesnt, which makes it a little harder. OK, not harder, but more time consuming since it's the same process.
I get a lot of good reports of happy drivers after just the fuel adjustment on my Facebook page. I makes a nice difference, but nothing wild & crazy. That's another story.
Old 03-03-2012, 04:19 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Crank er up!
Solenoid problem? excelstillmore 1994.5 - 1997 7.3L Power Stroke Diesel 10 06-27-2016 08:00 AM
Sticking Starter Solenoid Relay cap4004 Electrical Systems/Wiring 38 06-07-2016 08:01 AM
96' F350 7.5L ignition solenoid problems cityjack 1987 - 1996 F150 & Larger F-Series Trucks 3 03-27-2016 07:45 PM
Ignition wiring issue gtotiger65 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-21-2015 01:35 AM
78 F150 Starting Issues Wooticus 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-16-2013 11:57 PM
Tags
1995, 700, 78, 95, duty, f700, ford, fuel, gas, ignition, problems, replace, solenoid, super, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
