Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 02-21-2012, 04:24 PM
gogreenwave gogreenwave is offline
Garage is empty, add now
gogreenwave is starting off with a positive reputation.
Seat hard to slide/tilt
Hello,
I have an 08 ranger ext cab and the passanger seat has become hard to slide forward and back. Also its really hard to pull the handle on the side to tilt the back of the seat forward to get behind the seat. Has anyone else had this problem?
Thanks
  #2 (permalink)
Old 02-22-2012, 10:10 PM
Ruffinit's Avatar
Ruffinit Ruffinit is offline
1996 Ford Ranger
My Garage
Ruffinit is starting off with a positive reputation.
Normally it's caused from dis-use (if that's a word) and humidity causing a rust layer to form. The fore and back movement are done on rails that have ball bearings. You have 4 bolts that hold the seat to the floor. Unbolt and pull the seat. Once it's out, lubricate liberally. I believe that there is also 4 bolts that hold the seat frame to the seat, you can pull the seat off the frame once it's out of the truck to get at the moving pieces easier.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
