That will work.. Make sure your tape hangs in there for the long haul, lol.. Get it taped up, and next year you go to start it some cold day and the starter wont kick over, cause the tape comes loose.. LOL!
The M50D is stronger than a T-5, but there is no aftermarket support for internals that I know of.
The factory shifter is adequate, but has bushings that can wear and the housing can leak fluid and, if you didnt notice when having it on the ground, the top cover leaks through the 'vents', so the should be plugged.
The Hurst is a sealed unit that will not leak and moves half the distance of a factory shifter. It is a nice unit. When I installed mine I reused the factory boots instead of the one that comes with it.
My swap is complete but it seems to not have much power my buddies 95 is the same. But its factory 5speed it has more power then mine both 3.55 i6 could tranny codes cause this? Also I don't have a nss yet I just crossed the solenoid to start it?
