XLT/lariat tailgate insert - Ford Truck Enthusiasts Forums
Old 02-21-2012, 12:47 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
My F250 has the insert but it's missing the lower piece. I assume it's a red reflector like the later Bronco's. Will one from a later Bronco (90) fit?
Old 02-21-2012, 01:54 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
What year is your truck?
There were two distinct Lariat panels.
1980-1984
1985-1986
Old 02-21-2012, 02:13 PM
86 and I'll assume that's what panel is on the truck but I can see evidence of a repaint so it looks like the gate was replaced at some point.
Old 02-21-2012, 02:43 PM
Here's a pic.
Missing piece is at the bottom, which is the left side in this pic.
Old 02-22-2012, 04:31 AM
RockWVU RockWVU is offline
RockWVU is starting off with a positive reputation.
i am looking for this also, mine is broke.
Old 02-22-2012, 09:08 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The 1987/91 & 1992/96 F150/350 tailgate finish panels are now reproduced by Dennis Carpenter = 800-476-9653.
Old 02-22-2012, 11:35 AM
Um... Mine's an 86...
Anyone have a picture of what it's supposed to look like? The panel itself is in pretty good condition. It had a little dent but I've since massaged it out, I just need the lower piece.
Old 02-22-2012, 01:46 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It is a Red reflector, which is not available separately
Old 02-22-2012, 02:26 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
^^^ Yeah, that's it. And Brad is correct; the red reflector part was not available separately. ^^^
That aluminum tailgate panel was designed for the 1985 - 1986 Lariat models, and it is not available anymore and no one reproduces these.
You could, however, put some sort of red vinyl in there. Or, you could replace it a panel from a 1985 - 1986 Ford Bronco (Ford oval on the left side) or with the more narrow 1980 - 1984 tailgate panel. I think there are still quite a few those left out there. The 1987 - 1991 panels and the 1992 - 1996 panels do not have the tailgate handle cutout section because the tailgate handle was relocated to higher up on the tailgate.
Old 02-22-2012, 02:31 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
I doubt anybody here will be able to fully answer your question since this isn't a popular modification. What you can do is go to the junkyard, measure the reflector on the Bronco, and then transfer the measurements to you tailgate panel. If they match, you're golden. If not, and the Bronco reflector is too big, you can try cutting it down, but it's gonna be hard not to damage the reflector.
Old 02-22-2012, 02:59 PM
Well the width is good, about 66 1/2" but the height of the later (90) Bronco reflector is wrong. The Bronco reflector is 3 3/4" but the space on the panel is only 3 1/2" wide.
Oh well... guess I'll whip out the good old metal sewing machine and close all the holes in the gate and run with just the stamped letters...
Old 02-22-2012, 06:17 PM
81ChopTop's Avatar
81ChopTop 81ChopTop is offline
81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.
Just going to throw this out there. I couldn't find a nice panel either, so I attached a piece of stainless with the Ford oval on it. This is on my '86.
Old 02-22-2012, 07:27 PM
Quote:
That looks really nice! Is that just like flat stainless stock? where did you get it? did you just glue it or what?
that looks like our best option!
Old 02-22-2012, 07:39 PM
81ChopTop's Avatar
It's just flat stainless that I got and had sheered at the local steel supplier. Did a little polishing on it to shine it up a little. It's attached with the gray 3M molding tape.
That was about the only thing I could come up with that looked good. Thought about putting a brushed finish on it, but now I can not get it off to do that.
Old 02-23-2012, 11:52 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
How about cutting a piece of plexiglass and painting it red on the back side? Years ago, we used to buy clear plastic bodies for slot cars. These would be painted on the underside and the color would show through, be shiney and would not chip off when wrecked. Just an idea.
LMC cup holder F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-10-2016 10:47 AM
f-100 4x4 emblem inserts 66 4x4 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-28-2015 12:22 PM
Uploading Photos 1985 Bronco User Gallery & Picture Display 0 07-29-2014 05:57 PM
Tags
199296, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
