Brake Lines - Ford Truck Enthusiasts Forums
Brake Lines
Old 02-21-2012, 10:27 AM
regidog regidog is offline
regidog is starting off with a positive reputation.
Brake Lines
Any recommendations where I can purchase a set of pre-bent brake lines for a 1992 F350? Thanks
Old 02-21-2012, 01:16 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
no such thing anymore. just go to an autoparts store and get some poly-armour lines they are hand bendable and very easy to use.
Old 02-21-2012, 05:00 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
lmc truck or national parts depot.
Old 02-21-2012, 05:56 PM
Thanks for the information
Old 02-23-2012, 07:36 AM
Called around to all the big name suppliers, for some reason prebend brake lines for a 1992 F350 crew cab is not available but 1993 and up is and 1989 and below is
Old 02-23-2012, 10:46 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
i would have never thought they even made brake line cut and bent to fit directly.
i have never looked into that.it's not hard to grab some line,a decent double flaring tool and make your own lines up.the stuff cuts and bends as easy as pie.pretty cheap and available everywhere.
pre-bent brake line made to fit a '93 will fit your '92 of course.if for some odd reason,you find a different connector that doesn't work,you just grab the correct adapter(s.) but i would imagine your going to pay for the convenience and likely still need to tweak lines to fit.
fuel lines and brake lines install alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-28-2012 07:48 AM
Steel brake line that feeds the rear brakes jbondi 1978 - 1996 Big Bronco 10 10-30-2009 05:16 PM
Brake Lines xd2200 1987 - 1996 F150 & Larger F-Series Trucks 1 02-13-2004 09:54 PM
Brake line sealant? Torque1st Garage & Workshop 16 09-21-2002 09:35 PM
Rusty Brake Lines rocktestr 1987 - 1996 F150 & Larger F-Series Trucks 10 02-11-2002 12:06 PM
Tags
1992, 79, brake, cab, crew, f250, ford, line, lines, prebent, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
