"Active Duty" fuel pressure gauge?
So this is just an idea I had. I don't know if it's already available or not, but instead of finding that out I'm just going to discuss it with you guys.
So we're all familiar with the aftermarket oil pressure gauges, right? I mean the mechanical ones that actually hook into the oil system to read the pressure directly.
Is there something similar for fuel pressure, or do you think that a mechanical oil pressure gauge would work for fuel pressure? Or maybe, perhaps, one could outfit a fuel pressure gauge to be permanently installed in the cab, and read pressure from the shrader valve?
I'm just curious on this. I realize there's probably some logistical challenges to get around, such as making sure that fuel doesn't end up spraying all over the inside of the cab, and you don't set your truck on fire.
I just think this type of thing would be handy, so if you're driving and your truck quits all of a sudden, you can check fuel pressure just as easily as you can your oil pressure.
It's probably too dangerous to work, but it's fun to ask.
http://www.autometer.com/tech_faq_an...px?sid=1&qid=1
If you want to run one in the cab look for an electric one. It uses a sensor that goes on the Schrader valve under good and sends signal through wires to the gauge in the cab
The electric fuel pressure gauge is the safest and cost
the most.
There are the electric/mechanical type that use a solution such
as antifreeze in a tubing/hose that comes into the interior to
the gauge and are cheaper than the full electric type.
The expensive ones use a sender and a wire. (No hose).
The electric Autometer fuel pressire gauge uses a sender
and also a seperate black box that supplies voltage to their sender.
For both types of fuel pressure gauges, you remove the schrader valve.
Here's a picture of my Stewart Warner electric fuel pressure
and oil pressure gauge. Both use the same model sender.
Just one wire for each gauge comes into the cab.
the most.
Summit, Jegs, etc.
Analog, 0-100 psi, fuel pressure gauges at Summit: http://www.summitracing.com/search/D...i/?Ns=Rank|Asc
From those:
Liquid filled mechanical: http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
And from those:
1-1/2" Diameter: http://www.summitracing.com/search/D...r/?Ns=Rank|Asc
The only issue with mounting the gauge directly on the rail, is that you won't see it while you're driving. I run a mechanical liquid-filled 2-5/8" diameter gauge on my XR7. It's mounted under the cowl, in clear view from the driver's seat.
The rule of thumb here is that you can run a mechanical gauge if it is outside the passenger compartment. If the gauge will be inside the cab, use a gauge with an electrical sending unit.
From those:
And from those:
genscripter
09-02-2017 12:25 AM
cutthroatxxx
10-09-2014 08:53 AM
nlemerise
08-10-2006 01:13 PM
