led bulbs for gauges - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-20-2012, 10:17 PM
goosehunta's Avatar
goosehunta goosehunta is offline
goosehunta is starting off with a positive reputation.
anybody got the info for what size leds i need to replace the old bulbs in the gauges of my 06. also i see the blub for the 4x4 selector switch is a different type what is it? im not worried about the radio because i have a after market one. but i need sizes for the gauges, auto climate control, 4x4 selector. i think thats all. i looked online and found website that sold them but cant find what sizes i need.
thanks in advance.
Old 02-20-2012, 11:48 PM
the truth's Avatar
the truth the truth is offline
the truth is starting off with a positive reputation.
I would love to swap mine out for amber one's.
Old 02-21-2012, 12:06 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
You need these, this color is Blue but if you look up on superbrightleds.com Another thing to consider is that the actual gauge card is printed green so if you want a color to shine through you need to remove(scrape) the card. Very time consuming and tedious. These are just for the gauges. The led's in the switches have to be removed and soldered in new leds. Here is a great write up http://www.ford-trucks.com/forums/10...rking-now.html
2 x "B8.5D" LED (AC control panel) Instrument Cluster and Gauge Backlights - Super Bright LEDs
6 x "74-xHP" LED (Gauge Cluster) #74-xHP LED CAR BULB Specifications
Old 02-21-2012, 12:08 AM
cbzdel cbzdel is offline
cbzdel is starting off with a positive reputation.
I think I looked this up several weeks ago, and if I remember correctly all bulbs for the switches are not serviceable, well it requires breaking the units apart and then gluing then back together. But dont quote me on that haha.
Old 02-21-2012, 07:28 AM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Here is another good article on changing the dash over to LEDs, thanks to 1975Stroppebaja for the writeup!
2004 F250 LED Dash Lighting
Old 02-21-2012, 06:54 PM
goosehunta's Avatar
thanks guys. now how about the upfitter switches???
i havnt pulled the switch box out to see if i can see the bulbs.
Old 02-27-2012, 05:03 AM
willietwosix's Avatar
willietwosix willietwosix is offline
willietwosix is starting off with a positive reputation.
when i did my uplifter switches i had to open the actual uplifter switch unit and cut the old less off the circuit board and solder new ones on to the extra long original leads... takes a bit of skill... but its not that hard... just make sure you solder the correct terminals (++ --)
Old 02-27-2012, 07:05 AM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Also dont forget if you remove the gauge card you need to find out some way to put the needles back on in the correct spot.
Old 02-27-2012, 07:32 PM
goosehunta's Avatar
kool thanks for the info
Old 02-28-2012, 05:40 AM
AirborneCav's Avatar
AirborneCav AirborneCav is offline
AirborneCav is starting off with a positive reputation.
I have a bulb out in my dash and would like to switch to LED's. I have a 2001 SD, would it be the same LED's as mentioned in comment #3? I just want to do the dash lights is a bright white (to display as bright green).
Old 02-28-2012, 05:55 AM
xmontex4's Avatar
yup should be if not you could always double check with post 5's link its a 2004 so its identical.
Old 05-12-2013, 06:27 PM
cmartin248 cmartin248 is offline
cmartin248 is starting off with a positive reputation.
I just changed out all my dash bulbs on my 2006 King Ranch and I ordered them from ebay for $5 for 20 of them. They are T5 or #74 LED's and are about twice as bright as the original. Two things to know.. You must install the LED in the proper polarity or it will not work. I marked one side of the bulb holder with a black marker and checked each bulb in the holder so that the black mark was the positive side. Turn the black as looking at the back to the 2 o'clock position. The second thing is that if you change the "battery" (charging failure) to LED, you will notice that the battery light will be dimly illuminated even if everything is okay. This is due to the very low amperage draw of the LED and the way the charging circuit is made. The next time that I take my dash out, I will change it back to the old bulb type.
Old 05-12-2013, 10:37 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
I did mine a few months back and was not that happy with it
so I will be doing something else or going back to the old style
lamps. I was not happy with the hot spots the LEDs creates.
Hot Spot as in too bright. If I could get it to defuse more I would
be happy. Any ideas?
Sean
Old 05-13-2013, 06:50 PM
Yep,, I know what you mean by the hot spots, but they are much brighter and I like them anyway... I did try two different LED types and they both had the hot spots. Best of all you should never ever have to replace them...
Old 11-07-2015, 09:19 PM
Necronommicon's Avatar
Necronommicon Necronommicon is offline
Necronommicon is starting off with a positive reputation.
Hey guys, just found this during a search. Are the bulbs for an '06 250 cluster 194's or the 74's? I think I'll just stick with incandescent. I can't get a straight answer anywhere I look. Thanks.
Questions About Full Exterior LED Swap iRockFosgate 1987 - 1996 F150 & Larger F-Series Trucks 38 12-22-2016 10:40 AM
Led headlights Bat4x4 2017 Super Duty 11 08-23-2016 08:06 PM
HOWTO - Add LED Lights Luke76 '80-'86 HOWTO's 70 03-28-2016 08:09 PM
Instrument Cluster & Radio Restoration Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 59 06-28-2015 05:47 PM
Pic request: White or Green LED bulbs in gauge cluster PhillyB 1987 - 1996 F150 & Larger F-Series Trucks 12 02-01-2013 01:33 AM
Tags
02, 2000, 2004, blue, bulbs, change, color, dash, f250, f350, ford, gauge, gauges, led, lights, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
