Skipping second
With no +12V to power the Keep Alive Memory (KAM), which is volatile RAM, the codes will be cleared. Whomever told you otherwise is completely wrong.
In your other thread about this transmission swap I recall you had issues/questions about the difference in MLPSes and their related connectors. The solenoid block connector is also different between your 1993 and the 1995 truck.
This is the 1993 solenoid block connector:
This is the connector for the 1995 and up E4OD:
If you did not change the solenoid block then you have two issues going on here. First, the old style connector can be forced to fit on the newer block, but you will most likely have connection problems. The second issue is the 1995 and up solenoid blocks do not have the solenoid protection diodes on them, Ford moved them to the PCM. These diodes are designed to protect the driver transistors in the PCM from the voltage spike that occurs when power is removed from the solenoids. Without those diodes you risk ruining your PCM.
Two options here. First is putting your old solenoid block in the newer transmission. It is a plug and play swap. The second would be to use the PCM from the 1995 truck. You would still have to overcome the connector issue you are now facing.
Well without the proper diagnostic tool, or having someone else use there tool to check for codes you might as well as just put up a dart board and start throwing darts. Who knows, you might get lucky.
That said, lots of good advice has been ventured out so far, advice that points you in the proper direction to proceded. ANYTIME you are dealing with a computer controlled system, the second item to check for is codes. What is the first Check for loose / poor battery cable connections. Do these two items first... then proceed further. Jumping into the middle of things just gets costly.
My two cents, David
My two cents, David
compressorguy
05-18-2019 09:47 PM
aclaybor
02-03-2017 01:32 PM
partschangerlol
01-15-2013 03:09 PM
countyboy22
21
08-26-2012 04:20 PM
kiohio1985
08-30-2006 08:20 AM
