3-speed Shifter Linkage - Ford Truck Enthusiasts Forums
Old 02-20-2012, 09:22 PM
ratrod1923 ratrod1923 is offline
ratrod1923 is starting off with a positive reputation.
I'm trying to convert my 1981 F100 back to a column shifter from an after-market floor shifter. I have the original 3-speed column in the truck but I need the linkage from the column to the transmission.
Old 02-20-2012, 10:01 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Is this what you're after:
Old 02-20-2012, 10:30 PM
Quote:
The tag on the tranny has the following numbers:
RAT EY GB9
E2TRCA 1564
Old 02-20-2012, 10:32 PM
Yes, sir that is what I need.
Old 02-20-2012, 10:41 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Is it just me or does that look like there's no way in hell that should work?
BTW, a column shift manual is an EXCELLENT anti-theft device...
Old 02-20-2012, 10:58 PM
ctubutis's Avatar
ratrod - I moved your post in the free-to-good-home thread to the JY Wishlist, it seems to belong there and not in the former.
Old 02-21-2012, 08:42 PM
ctubutis's Avatar
Quote:
RAT EY GB9
E2TR-CA 1564
Best thing you can do is find a 1980/81 3-spd in the junkyard and take the parts from it.
Those rods don't seem to be available NOS anymore:
E4TZ-7326-A - High & Intermediate
E0TZ-7328-B - Low & Reverse
Perhaps the part numbers have been superseded, perhaps they're just plain gone.
Those 7341 nylon bushings are NLA, too.
I found some places that say they have the 7285 & 7290 things (for connecting at the transmission) but no idea what they'd cost. But, without the rods, what good are they?
1982+ uses different parts, make sure the transmission tags match.
Old 01-14-2014, 03:00 PM
3ontheTreeisKillinMe 3ontheTreeisKillinMe is offline
3ontheTreeisKillinMe is starting off with a positive reputation.
Column Shifter - 1986
E0TZ7228D / E0TZ-7228-D
Hey, These are practically impossible to find. If anyone needs one, PM me. I have an '86 F-150 and the column collar snapped one morning (the little plastic sleeve had bound up) when it refused to go into 1st. Anyway, impossible to find a replacement collar. No parts, no custom parts, no junk yards. However, I found another post somewhere (I'll gladly give this guy the props when I find his post again) where someone took a '79 column shifter and cut it down to fit. Claimed it worked just like the original.
ABSOLUTELY IT DOES! I picked up a '79 column collar, rigged up a cutting jig for my Dremel, took a bit off the top and I'm glad to say that it is indeed working as well as the original - minus that pesky plastic sleeve that refuses to go back in and is ALSO impossible to find.
I know this is an ancient post, but, if you're looking to convert because you can't find a replacement column collar for your 1986 F-150, let me know and I can cut one down for your.
Honesty caveat: The original collar had a narrower lower end because there is a steering column casing that wraps around the collar and the column. The '79 is the same diameter from top to bottom so putting that column sleeve back on might not work. Myself, I epoxied some velcro on the inside of the sleeve so, from top and side, it looks perfect. However, running without it isn't the end of the world, it just exposes the ignition actuation rod on top and wiring bundle of to the lower side.
I may actually have another I can cut down for sale.
Last edited by 3ontheTreeisKillinMe; 01-14-2014 at 10:40 PM. Reason: Corrected part numbers
Old 01-14-2014, 10:07 PM
ctubutis's Avatar
Thanks for posting this! yes, the 3-on-the-tree shift collar & miscellaneous parts are virtually impossible to find these days, pictures of what you did would really be splendid! *hint* *hint* *hint*
BTW a question... did you mean for both part numbers to be 7228? I'll bet you did....
Old 01-14-2014, 10:39 PM
Ahhh, yes, I absolutely DID mean them to be the same! Thanks for the catch!
No worries, I've collected pictures and measurements through the process and I'm putting them together into an "Instructable". I'll post the URL when it's finished. Should have it finished in the next few days.
Old 01-14-2014, 10:48 PM
ctubutis's Avatar
Cool, thanks for everything!!! Reps for this.
I'll add your HOWTO to the subforums at the top of the forum (the Sticky will eventually go away) and hopefully your stuff will be found by people doing Google searches on that part number.
This broken-shifter-column thing has been an issue for years, using 70s parts is downright ingenious & resourceful, thank you for sharing.
Old 01-15-2014, 12:29 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Old 01-15-2014, 01:06 PM
Great video - WHERE WERE YOU LAST MONTH! ;-)
My shift collar ('86) broke in the exact same spot. From what I hear it's a very common problem. I had a heck of a time finding documentation on how to take everything apart - your video does a great job explaining some of the trickier problems - like those square bolts. After unscrewing just about every bolt and crawling underneath the dash, breaking my knuckles to get that wiring harness out, I found that by removing the steering column bracket (two bolts) and lowering it down allowed very easy access to the cable connector as well as the ignition "initiator". The box where that ignition rod goes in. If found I could unbolt it (two bolts that also held in one end of the ignition cable connector on mine) and the rod just pops out of it's hole. Easy to pull the cable and rod, still attached to the top wheel assy, out through the broken shift column. My ignition rod was bent around the upper arm and I didn't want to bend it out of form to remove it. Removing the lower assy was, once I figured it out, a much easier route and left everything in original shape. As for those square bolts, I found that by pre-bolting them into the top assy with just a turn or two of the nuts allowed me enough play to shimmy the unit into position. With very little persuasion the bolts just popped into those cut-outs. When I tightened them up I just applied a bit of side pressure on the socket and they stayed right in position. Again, after MANY trials and errors, this worked well for me seeing as I had to do this a few times. After all, how many times can you reassemble and STILL have left over pieces? Apparently quite a few... Lastly, given the apparent fragile nature of the piece, I declined to pound in the new shifter retainer pin. I dropped in a very nice 1-1/2" bold, a washer and a locking nut. Fits snug, works great.
How did that JB Weld hold up? Mine didn't pop the welds (yet) and if it does I really don't want to have to pull the entire column to have it spot welded back on.
Good job!
Cheers...
Old 06-27-2014, 10:55 PM
DHCowdude's Avatar
DHCowdude DHCowdude is offline
DHCowdude is starting off with a positive reputation.
If anyone is still looking for those two long, twisty shift rods - I have 'em.
Make me a decent offer plus shipping from NW Ohio and they're yours. May even have one or both of the transmission levers to boot.
Old 06-28-2014, 01:32 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1980/87 F100/350 & Bronco 3 M/T: E4TZ-7326-A - High & Intermediate / EOTZ-7328-B - Low & Reverse
The part numbers have been obsoleted.
Uh huh (sigh)
EOSZ-7341-B (replaced EOSZ-7341-A; D5TZ-7341-A, B & C; D4TZ-7341-A; D0AZ-7341-A; C7SZ-7341-D; C3AZ-7341-A) .. Gearshift Selector Arm Nylon Bushing / Available from Ford.
Applications: Myriad 1963/90's Passenger Cars/F100/350's/Bronco's & Econolines with A/T & 3 M/T.
Column shift Shane Carruth 1961 - 1966 F-100 & Larger F-Series Trucks 18 06-14-2016 06:05 PM
61 F100 Column Shift Parts SThompson 1961 - 1963 F100 Unibody 4 08-14-2015 02:11 AM
Automatic transmission shifting Gigemags05 1947 and Older Ford Trucks 2 12-03-2014 05:24 PM
79 shifter linkage ford7872 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-27-2013 04:33 PM
C6 Column shift on the stock column... can it work? JDBeck23 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 09-25-2012 04:46 PM
Tags
1983, 1997, bronco, bushing, diagram, explorer, f100, ford, ii, linkage, removal, shift, shifter, speed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
