1997 7.3 won't start no fuel pressure - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-20-2012, 06:14 PM
Domino2205 Domino2205 is offline
Domino2205 is starting off with a positive reputation.
Hello and thanks for help ahead of time. I was driving my truck the other day and the power started going away until nothing and similar to running out of fuel.
most everything I have seen with the problem points to the injector control or the under valve cover connectors. I checked all the connections and they all look good. The fuel bowl where the filter is is full and cranking engine over there is no fuel pressure at all and I can hear the injectors clicking so I believe its the lift pump that has failed. Is there something else I might be missing that would cause no fuel pressure other than the mechanical pump failing?? It would make sense its that and not something electronic but the way the truck turns over is like no gas but fuel bowl is full just nothing leaving it.
Old 02-20-2012, 06:57 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
How did you check the pressure ? Usually when you have no pressure it is the pump ....could be a tank issue as well , But just in case drain the bowl and see if it fills up .....
Old 02-20-2012, 07:07 PM
I used a rounded pin on the schrader valve and when pushing in on valve after cranking theres no spurt of fuel and holding valve open there is none coming out while cranking. And I wonder on these with the 2 stage mechanical pumps that they pull fuel from the tank and then pressurize it to the system pressure. But when it failed power just fell of until nothing but the fuel bowl was full so it was getting fuel up there, so I shall try that and drain it and see if it refills the bowl. Also isn't cranking it over with no fuel bad for the injectors??
Old 02-20-2012, 07:50 PM
blageurt's Avatar
Unplug the IDM fuse
Old 02-20-2012, 07:56 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
It is possible the high side of the pump has failed
Old 02-20-2012, 08:50 PM
thanks and based on what I think I know I would say the high side has failed but not positive
Old 02-22-2012, 11:30 PM
Thanks for the help from the masses here but I got lucky and the problem was the fuel pump bolts worked loose and that is what caused the loss of pressure and truck is back up and running and again I thank all those that took time out of there busy day to help out
no start/no white smoke 967.3zf5 1994.5 - 1997 7.3L Power Stroke Diesel 9 06-19-2016 05:14 PM
Fuel Pressure and Noise Problems after Blue Spring install Bryan Hagan 6.0L Power Stroke Diesel 15 02-27-2016 02:38 AM
NO start after HPOP/Lift pump install 93f250tn 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-09-2015 02:51 PM
NEED HELP!! No Start - Just cranks Trailblazed 1999 - 2003 7.3L Power Stroke Diesel 75 09-15-2012 05:44 AM
Fuel Problem - Won't Run mark_fussell 1994.5 - 1997 7.3L Power Stroke Diesel 5 09-18-2010 03:04 PM
Tags
1995, 1997, 73, bowl, diesel, f250, ford, fuel, preasure, pressure, problems, pump, start, volume, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
