5.4 major issues
Old 02-20-2012, 02:47 PM
unhcp's Avatar
unhcp
unhcp is offline
5.4 major issues
Was driving home in my 07 f250 5.4 its has 60,000 miles and the check engine came on, I pulled the codes and got p0012 and p0300. I just did all the coils and spark plugs less than 3,000 miles ago. I know it has at least 1 bad coil, I have had this issue before and it is behaving the same way, the question is the p0012. Engine seems to tick very loudly when I get around 2k rpms. I am thinking maybe the VCT solenoid, it is only coming from the passenger side it sounds like.
Old 02-20-2012, 07:45 PM
unhcp's Avatar
unhcp
unhcp is offline
I used a fram oil filter and Valvoline SynPower 5W-20 Full Synthetic Motor Oil.
Everyone says it could be something different
cam phasers
cam phaser trigger wheel - f150 forum
VCT solenoid
Exhaust Manifold
Just don't know where to start!
Old 02-27-2012, 03:31 PM
F250CCowner's Avatar
F250CCowner
F250CCowner is offline
Well manifold is easy to check and free to do so. I would probably start with there and go onto the cam phasers. They are known to be problematic in 3V engines. I have an 03' with a 2v engine and other then them being known for spitting plugs when not torqued properly they are pretty bulletproof. Although I would like the power the 3v engines give you I don't want the headaches you sometimes get with them. Sorry I cant be of more help.
Old 02-27-2012, 06:42 PM
unhcp's Avatar
unhcp
unhcp is offline
My mechanic think its the manifold, tick gives it away.
Old 03-19-2012, 06:38 AM
unhcp's Avatar
unhcp
unhcp is offline
Replaced the passenger side manifold this weekend and a few coils, thing is running like new!
bigern6697
2009 - 2014 F150
34
03-28-2024 02:36 PM
chrism1215
2004 - 2008 F150
16
03-02-2015 10:02 PM
46fordtruck
2004 - 2008 F150
08-25-2014 06:45 PM
3vford
2004 - 2008 F150
01-03-2014 08:02 AM
thw1
2004 - 2008 F150
06-11-2012 08:27 AM
Quick Reply: 5.4 major issues
