Pitted oil filter housing. V10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-20-2012, 02:41 PM
Slingnsteel Slingnsteel is offline
Slingnsteel is starting off with a positive reputation.
I have a 99 250 SD with the V10. I have a small oil leak at the aluminum oil filter housing cause it's pitte a little due to corrosion. I would rather repair it rather than replace it. Any else have this experience and what thoughts on its repair. Another thought was use another filter with same diameter screw hole but a larger gasket.
SM
Old 02-20-2012, 05:50 PM
2000 excursion v10's Avatar
2000 excursion v10 2000 excursion v10 is offline
2000 excursion v10 has a good reputation on FTE.2000 excursion v10 has a good reputation on FTE.
yes. i had this problem a month ago. this is what i did u have to remove the oil cooler.
first fallow the two coolant lines that are connected to it up to the larger hose. then clamp them off to save all ur coolant from flying out then remove the hoses from the housing then remove the oil filter and inside of the threaded tube that the filter screws onto is a hex hole u need a large allen wrench (cant remember what size) once u have one that fits put it in there and turn it out as if u were removing a bolt and the hole housing/cooler will fall into ur hands next clean it up real well and find all the pitting spray out the pitting with card cleaner real well then buy some quick-steel brand putty and smash it in the pitting ans best u can let dry and reassemble.
Suggestion for installing inline coolant filter coolfeet 6.0L Power Stroke Diesel 0 04-13-2016 12:51 AM
Aftermarket Oil Filter Cap Woes FiveOJester 6.0L Power Stroke Diesel 8 01-17-2016 04:41 PM
oil draining from filter housing samsdad02 6.0L Power Stroke Diesel 24 12-09-2013 05:50 AM
weep holes in oil filter housing exiled 6.0L Power Stroke Diesel 7 07-02-2011 07:57 PM
Converting oil bath air cleaner to filter style Mike-fire32 401, 477, & 534 SD Engines 3 06-06-2011 01:12 AM
Tags
1968, 99, excursion, f250, f450, filter, ford, gas, housing, oil, parts, problem, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
