Trans Fault code
Trans Fault code
I recently had the Trans fault code show up on my message center of my 2006 f150, 4x4. A little back story, I was actually in mud at the time and was stuck, but I wasnt torturing it, if that makes sense. It threw the code and the od flashed. I shut it off and started it back up. I was then pulled out and have not had any issues with the forward gears, still shifts just as smooth as it always has and has no problem shifting up to 75 mph. When I put it in reverse, it seems like it take just a second longer to get in gear than before. Once in, I have no troubles backing up. I understand that I more than likely. We'd the codes read, but have a couple questions. Will my xcal 3 read the codes, also anyone have this happen before and have a hunch if there is something wrong with it? As always, I appreciate the help.
OK I have one question for you now.
You were in 4wd with the OD on?
If that is the case then most likely it flashed at you to simple say hey I don't like this and the tranny was heating up. When using the 4wd you should be in something other then OD or have the OD turned off.
I would guess that you have no issues but you might want to change the fluid and filter soon and clean it all out if you haven't done so already.
OD was not off, however it never shifted up so I do not understand that part, wouldnt it being in 1st make OD irrelevant? Just asking! I "rocked" it, but only by waiting for it to engage once I switched from D to R and vice versa All total it could have been maybe a minute, I had access to a tractor and was pretty deep, therefore I wasn't going to torture it. No it never shifted up to 2nd since I wasn't hammering on it. Partially why I got stuck.
The OD being on or Off is more a matter of how I drive my truck I guess. I turn it off when I put it in 4wd or hook a trailer up. I was thinking you had it in 4wd before getting stuck but then again not everyone does that.
Now as for what I was trying to say the computer most likely threw a code when it flashed the warning light but it didn't see it as being major enough to leave the light on just gave it as a warning. Basically saying hey I don't like this. Its the same thing when the CEL flashes from say a misfire that is only random its not enough to make the light stay on.
Did you cause a problem sure its possible the light flashed for some reason. If you post the codes from teh computer I am sure someone around here can give some more insight as to what they mean if you don't know already. Will the xcal3 read the codes I would imagine it would most decent tuners do.
Now as for taking longer to shift into reverse can you be sure it wasn't doing that before and you just hadn't noticed and are paying more attention now so you noticed it now?
06 f150
im also having similar issues! i have reverse but it will not engage in a fwd gear! the rpms go up andthe o/d blinks and also the trans fault comes up! the emissions light is on a gives me 3 codes p2106,p0174 and p0720 anyone have any ideas before i take it in the shop monday, giving the holidays i would too sve some $ but i also need this fixed asap. Thank you
grizzly11
16
07-24-2010 02:54 PM
