Injector Stiction? Will HSS and Rotella T6 5w-40 help?
I have been experiencing low power, poor mileage and rough running when cold. Did alot of my own diagnostics that I learned on here. Finally took it in to a local diesel shop and they performed an injector balance test. Test showed that injector #2 is almost dead, and #4 and #6 are not to far behind. When I plugged it in to a code reader prior to taking it in, no injector codes came up, which is causing me to believe that those injectors are possibly having a stiction problem. Instead of going right for the most expensive thing (replacing injectors) I purchased a 2qt jug of HSS. I have about 500 miles on the HSS, and Rotella T6 5w-40. I have been noticing that it has started puffing out a little blue smoke when it surges and runs rough. It never did this before. It seems to run better once it gets warmed up, but every once and a while will still lack power. Is it possibly a result of the HSS doing its job and cleaning out the varnished injectors? Or do you think the injectors are toast and I just need to buck up and replace them?
Sorry to say my friend that nothing I ever did unstuck the bad injectors in my truck. I replaced all of one side and eventually had to do the other side, had about 200K on the engine when it all happen. The good news is that the truck runs really great after this is done. Some have said that one of the causes of the injector problems is water in the oil, like you get from a egr cooler failure. I,m thinking that this helped wreck my injectors because the egr cooler failed next, but who knows. Cost for me was about 2400 or so, including belts oil, gasgets, I did the work my self but do not attempt it unless you are confident in your mechinacal abilities, one screw up and the truck does not start! Best of luck.
I think this: AR9100-16oz FRICTION MODIFIER-INTRODUCTORY PRICE along with the T6 will give you a LOT more bang for your buck and produce better results....
mohle-- will the failing injectors blow up motor??
i am having inj #1 #6 #7 issues, i tried BG fuel, oil, and oil treatment cost around 85 bucks changed nothing, hopefully i get new injectors this week..... was going to try the HSS, but to many differnent opinions on it working so didnt try it...
Now if your engine isn't running right you are probably going to run into problems further down the road if you keep driving it like that. Personally I'm not made of money and rather spend the money on a new injector now, rather than some rod bearings or a melted piston later.
