04 f550 6.0 diesel after fuel filter change start up stumbles alittle.... - Ford Truck Enthusiasts Forums
Old 02-19-2012, 11:37 PM
F-WhiteThunder's Avatar
F-WhiteThunder F-WhiteThunder is offline
F-WhiteThunder is starting off with a positive reputation.
i wrote a fuel filter change that i did on this 04 6.0 diesel f550 for my friend. so changed both fuel filter and put two new batteries in. it fires up but for about 5-10 seconds it stumbles like its clearing its throat. not a stumble like its going to die but alittle rough idle and then idles out fine. then runs fine after that. before i did the fuel filter change i dont recall that ever happening. any ideas?
Old 02-19-2012, 11:41 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
Did you cycle the key 5-6 times before cranking it?
Old 02-19-2012, 11:48 PM
no i did this about 2 weeks ago. its been ran and used. shouldnt have to cycle it several times every time i use
Old 02-20-2012, 12:09 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Did you use OEM filters? Did you put the new o-rings on and oil them before you put the cap back on?
Old 02-20-2012, 12:11 AM
yup ford filters. new orings and i put alittle red grease light thin coating according to powerstrokehelp.com
Old 02-20-2012, 12:16 AM
I think I'd pull the upper filter and make sure it's not draining back down. I don't know why that'd cause stumbling at startup, though. You may have nicked the o-ring on the lower filter, which can cause air to be pulled into the system. But again, that should cause problems all the time, not just at start.
I think I'd start checking the FICM voltage, operation of the EGR valve and check for codes. It could be just a coincidence that the problem started now.
Old 02-20-2012, 12:20 AM
yeah dude doesnt take care of it . 23 or 24k miles on it too lol
Old 02-20-2012, 06:13 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
WTS/WIF light flash and stall issue southtexasidi 6.0L Power Stroke Diesel 2 08-01-2016 05:58 AM
460 Randomly stumbles *updated. found chip* hoss khaos 1987 - 1996 F150 & Larger F-Series Trucks 13 02-21-2016 07:35 PM
Stumbling at 50-60 - Calling on some experts here MTNTIME 1999 to 2016 Super Duty 2 12-03-2015 03:20 PM
99 Navigator stumbles and runs rough chunger Expedition & Navigator 38 11-06-2011 04:23 PM
computer reset after air filter upgrade wizard 6.0L Power Stroke Diesel 0 10-17-2003 04:55 AM
Tags
2004, 60, change, diesel, f550, filter, ford, fual, fuel, location, powerstroke, repalcement, start, starts, stumbles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
