ipc question
Someone with more knowledge may chime in, but this is what I can deduce from taking the HPO system apart.
Changes in high pressure oil system are recognized by the PCM as the difference between the reference "in" voltage in and voltage "out" of the ICP sensor. The PCM then controls the oil pressure by regulating the opening and closing of the high pressure oil bypass valve or IPR. When the IPR opens, oil will flow directly back to the HPOP, which then reduces the oil pressure to the injectors. Failed open IPR will not allow the HPO system to increase oil pressure. A clogged IPR would cause a loss in the ability for the PCM to properly regulate the oil pressure on the high side.
fishforlife2007
18
02-15-2015 02:31 PM
