transmission temp sensor - Ford Truck Enthusiasts Forums
Old 02-19-2012, 06:35 PM
Lance4986's Avatar
Lance4986 Lance4986 is offline
Lance4986 is starting off with a positive reputation.
2005 f-250
tow/haul light flashing and check trans temp shows up on display.
transmission goes into limp mode shifts really bad and also throws its self in and outta gear
im guessing my temp sensor has gone bad. should i change the sensor and the internal harness?
am i on the right track to fixing the problem or am i completley wrong
Old 02-19-2012, 06:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
You're most likely right. I recommend changing both the sensor and the internal harness. 90% of the time it's the sensor, but it should would be annoying if it were the harness this time!
Old 02-19-2012, 07:06 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
What is the service history on the tranny? Type of fluid, mileage on changes, flushes, external filter change etc.
Old 02-19-2012, 07:41 PM
Lance4986's Avatar
i have around 90k ont the and the transmission was rebuilt around 50k
that was the last time the fluid and filter were changed
i use motorcraft mercron sp fluid
Old 02-19-2012, 10:51 PM
Randy777 Randy777 is offline
Randy777 is starting off with a positive reputation.
Rebuilt at 50,000! Do you tow super heavy? I thought these trannys were good to 150,000 plus.
Old 02-19-2012, 11:09 PM
Lance4986's Avatar
some how water got inside the transmission either from the coolant lines or maybe from launching boats. it was a big surprise to me aswell
Old 02-20-2012, 08:13 AM
These transmissions are good for 250,000+ miles if water doesn't get inside.
Old 02-20-2012, 09:20 AM
69cj's Avatar
You are past due for a tranny flush and external filter change. Every 30,000 miles min.
Old 02-20-2012, 10:44 AM
Sark Sark is offline
Sark is starting off with a positive reputation.
Thumbs up
Quote:
Some might say I service my tranny too often as I have the dealer do the flush every 15,000-18,000 miles.
I'd rather be safe than sorry as 60,000+ of the 80,000 miles on the trk have been towing our 1/5 whl trailer with a combined weight at 21,200lbs. which is a pinky over the max. gross for the trk.
If we didn't tow as much at the max. gross then I'd go with the recommended 30,000 change interval.
Old 02-20-2012, 01:24 PM
Lance4986's Avatar
Does any one have a picture of where the sensor is located so I'll know just what Im looking for when I go to change it
Coolant Temp Sensor castrovinci Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-17-2013 10:42 PM
Coolant Temp Sensor savage250 1994.5 - 1997 7.3L Power Stroke Diesel 2 02-01-2012 11:43 AM
94 bronco temp sensor bh70116 1978 - 1996 Big Bronco 3 08-29-2010 07:32 PM
Is it a bad temp Sensor or? idahodisco Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 03-15-2010 12:14 PM
Is the parts guy nuts or am i ? SOB Racing 1999 to 2016 Super Duty 5 03-27-2009 01:27 PM
Tags
2003, 2005, 46, f150, ford, good, kit, replace, sensor, switch, temp, tranny, trans, transmission, transmittion, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
