How to clean a Mass Air Flow (MAF) sensor - 5.4L - Ford Truck Enthusiasts Forums
Old 11-18-2014, 04:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Old 02-19-2012, 10:06 AM
CelticDevilDog's Avatar
CelticDevilDog CelticDevilDog is offline
New Mexico Chapter LDR
CelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputationCelticDevilDog has a superb reputation
I know that this is an incredibly simple process but sometimes I find things easier with pictures. I couldn't find anything like that on this site, there were lots of references to cleaning the MAF and I wanted to clean mine. I figured I would create a simple tutorial and give back to the community that has helped me so much.
Here are the tools you will need:
1) CRC Mass Air Flow Sensor cleaner. Do NOT use break cleaner or anything else that is not designed for electronics. About $8 at a local parts store.
2) Flat head screw driver
3) T-20 Torx bit
The MAF is located on the driver's side of the Air filter housing
Use the screwdriver to pull the red tab out. It pulls out like a drawer and not up or down like many tabs.
Gently pull the connector off the MAF. If this has never been done on your truck before you may need to use the screw driver on the red tab to give you a little more help. It should slide right off.
Next, use the T-20 torx bit to remove the two screws holding the MAF to the air filter housing. There is one on the top left of the sensor (shown below) and one on the bottom right of the sensor.
Gently pull the sensor out. Be sure to not get any dirt into the air filter housing when you remove the MAF.
Spray the MAF and let it dry for about 10-15 seconds. Do NOT touch the wires in the MAF with anything other than the CRC cleaner.
To put it back follow the procedure in reverse order.
Cleaning the MAF is a good idea every time you change/oil your air filter as it can get dirty from all the dust and oil that may come through your air filter.
If you have any questions or there is more information I can add to this tutorial let me know.
Old 02-19-2012, 10:54 AM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
The hardest part about this for me is finding a stupid torx driver...lol. Great write up though and I honestly do need to do this soon. I hav'nt even checked mine since I bought the truck.
Old 02-19-2012, 11:14 AM
tbear853's Avatar
tbear853 tbear853 is online now
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Thumbs up
Great short & to the point write up .... I too need to do this, I need to get the CRC first as I keep forgetting and everytime I think about it, still need the spray.
My 07 has near 40K and it's never been done either. I doubt it's ever been done on the '95 TBird at 75K and I know it hasn't on the Merc or Subaru. Maybe on the '92 TBird .... loooks like I'll use up a can .... haha
Gotta get back up there to the Frost Diner here soon! Get some Hank and Lefty going on the juke ....
Old 02-19-2012, 11:27 AM
Gundown64's Avatar
Gundown64 Gundown64 is offline
Gundown64 is gaining momentum as a positive member of FTE.Gundown64 is gaining momentum as a positive member of FTE.
Thanks a lot for this. I need to do this and even though it is so simple, I didn't know the correct way to do it so this helps a lot. Reps sent your way!
Old 02-19-2012, 12:01 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Added to the tech folder.
Stewart
Old 02-19-2012, 02:57 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Bobbie, great write up. Well done. Very easy process.
Old 02-19-2012, 05:06 PM
Thanks all. It took me a little while to figure out how to do it properly that I figured what better way to learn than to also help someone else in the process.
Old 02-20-2012, 06:07 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Quote:
Great write-up! I have 82K on my truck and have never done it... Thanks for taking the time to detail the process!
-Steve
Old 02-20-2012, 07:38 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Well done Bobbie!
Old 05-11-2012, 05:59 AM
baby ape baby ape is offline
baby ape is starting off with a positive reputation.
will this help with fuel cost? i have a 2008 f-150 5.4 v-8.i chipped it and gained super hp and some fuel economy.
baby ape
Old 05-11-2012, 09:04 AM
ctsv510 ctsv510 is offline
ctsv510 is starting off with a positive reputation.
Quote:
baby ape
Cleaning the MAF helps the sensor be as accurate as possible so you get the right amount of fuel for the amount of air going through your motor. A dirty MAF can misread the amount of air, but it is more likely to cause a lean condition (not enough fuel) than using too much fuel. It is a good maintenance procedure to keep everything running smoothly, but don't expect to gain any noticeable MPG.
Old 05-12-2012, 04:24 AM
mitch150's Avatar
mitch150 mitch150 is offline
mitch150 is gaining momentum as a positive member of FTE.mitch150 is gaining momentum as a positive member of FTE.
Thumbs up Nice write up!
Nice write up Dog. And just to add, for those of you running with a CAI or permanent washable filter, especially do it after re-charging or cleaning the air filter and or check it after you've put the filter back in and driven the truck. Your supposed to let the filter set and the charging oil dry properly, but I have seen where some might not wait long enough for that and after running the truck, some of the charging oil will get on the sensor, sometimes that will happen even after it does dry long enough, I've seen it happen. Anyway, that will mess with how the sensor is reading the a/f mix, just my 2 cents (and it's not even worth that )
Old 03-22-2013, 05:28 PM
05Edge's Avatar
05Edge 05Edge is offline
05Edge is starting off with a positive reputation.
Just did this for the first time today. Thanks for the awesome write up!
Old 06-14-2013, 10:05 AM
red dog red dog is offline
red dog is gaining momentum as a positive member of FTE.
maf sensor
Excellent detail!
I see its been a year but i just came across it.
Do you just spray into the hole where the wires are or do
you spray the whole thing. Also, do you spray sparingly or
do you wet it real good. Thanks!
Old 06-15-2013, 07:45 AM
You should spray the whole thing but spray it lightly. You don't want to have any electronic part soaking wet.
2003 F350 Dually Cummins Conversion for sale billyrb Vehicles for Sale 1 08-08-2015 04:15 PM
New to me 05 Ex CelticDevilDog Excursion - King of SUVs 11 01-22-2014 10:16 AM
New to the site. Would like to see your drag cars Shua General Automotive Discussion 0 02-14-2011 06:29 PM
well, I may not be a genius... dogmantra 1973 - 1979 F-100 & Larger F-Series Trucks 36 10-31-2010 09:30 PM
Rednecks rock! westtnfx4 Offroad & 4x4 139 05-03-2010 08:05 AM
Tags
07, 2004, 54, 54l, air, clean, cleaning, f150, flow, ford, fordf250, maf, mass, massl, sensor, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
