excursion, 4x4 wont shift - Ford Truck Enthusiasts Forums
Old 02-19-2012, 09:34 AM
fordssawslogs fordssawslogs is offline
fordssawslogs is starting off with a positive reputation.
Cool excursion, 4x4 wont shift
hi long time member first question,
we have a 2002 excursion i have replaced the 4x4 selector switch on the dash as well as the front hubs they are now the warn premium hubs and the transfer case shift motor all part are ford all but the hubs.my question is it will not shift from 2 hi to 4 hi to 4 low,i have done all the right things that the book says to do,put vic in neutral keep foot on break,switch selector switch to 4x4 or 2 or low and it will not shift.when the transfer case shift motor was off i put the truck back in 2 wheel drive by hand with a wrench and it moves free no binding what else could it be the fuse under the steering wheel is good and new parts are good as well any help would be great
4x4 2002 excursion limited 7.3 only mod is cold air intake
thank you for your time
Old 02-19-2012, 10:41 AM
whitewhale whitewhale is offline
whitewhale is starting off with a positive reputation.
check all of your connections, and I actually pulled the shift motor off of the transfer case when mine was acting up. Cleaned up my connections and cycled the motor a few times and it worked fine
Old 02-20-2012, 01:03 AM
i will give it a try
as soon as i get home from afganistan i will give it a try i bought the big suv for the wife and kids to be safe in but with all the small things that have happened with it the wife just drive her mini van,heartbreaking haha but thank you for the advise is there any place under the hood they have a relay or a conetion that needs to be cleaned or just the ones under the truck at the shift motor
Old 02-20-2012, 02:52 PM
Studawg's Avatar
Studawg Studawg is offline
Thread Ender
Studawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to all
You know you will have to manually turn the hubs to LOCK first, and then, turn the switch, for the 4WD to engage. If I am not mistaken, with those Warn hubs, your truck is no longer "switch on the fly".
Old 02-21-2012, 08:20 AM
the new hubs
yes i know about the new hubs but the factory ones were 4 times as much as the warn the warn has a lifetime warenty and the air house was also no good so i just went with the same hubs ive but on all my trucks,we live in fairbanks alaska so the hubs are locked for about 8 months out of the year
Old 02-21-2012, 09:34 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Attached is an EX wiring diagram for ESOF 4WD circuits. Bottom right hand corner shows the Low to High and the High to Low relays. Not sure where they are but on a truck they are under the hood near the master cylinder. If your EX has the tow package there might be another set of 2 relays. The 4WD relays will be the two mounted further forward.
The only pic I have are the 4WD relays under hood of my 99 truck.
Be safe over there and come home safely.
See bottom right hand corner of his wiring diagram for the 2 x-fer case shift relays.
Fuse 59 supllies power to the relay windings as well as to the x-fer case shift motor through contacts of these relays.
Edit : On the right side of drawing is the 4WD Control Module. Could be the problem.
Old 02-21-2012, 10:08 AM
PaysonPSD's Avatar
I should have added this to my previous post.
The ESOF relays are a Bosch 5 spade type. They have a normally closed contact not found on the four spade relays.
I had the same problem you have. I removed and bench tested the relays for continuity from 30 through normally closed contact to 87a when non-opeated and continuity from 30 through the make contact to 87 when operated. All was good. Before plugging the relays back in I cleaned the spade contacts with emery cloth. Shifts to 4HI and 4LOW and back again then worked. I don't know if exercising the relays or cleaning the spade connectors is what helped.
Old 02-21-2012, 07:54 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
I didnt know if you use Warn hubs that you cant use the ESOF. Is Ford hubs the only ones you can use with ESOF? Was thinking about changing mine out when I change out the rotors.
Old 02-22-2012, 04:12 AM
as far as i know you can use any hub ,what i do in Alaska
is leave the hubs"locked" and just shift in and out of 4x4 4x4low and 2 wheel drive(before the curent issue were having) shift out of 4x4 and the front drive line wont spin ive never had a problem doing this on older trucks and on the newer ones as well just my opinion and history
Old 02-22-2012, 04:27 AM
PaulDH PaulDH is offline
PaulDH is gaining momentum as a positive member of FTE.
With the Warn hubs locked, the front axles and and the front drive shaft will be turning constantly, whether the transfer case is engaged in 2WD or 4WD. Which consumes some additional energy and accelerates the wear on the U-Joints in the front axles and front drive shaft, and on the splined joint in the front drive shaft.
Old 02-22-2012, 04:52 AM
wow this seems like it will help alot,i will be able to let you know if it works in about a month and a half thank you very much sir for the help
Old 02-22-2012, 12:44 PM
Hey,
I didn't mean to lead you to believe that you'll have 4WD functioning without the transfer case electrically engaging into 4WD High or Low. Without the transfer case engaged into 4WD, but the Warn hubs locked, your front axles and drive shafts will be rotating whenever the front tires are rolling because the front axles are mechanically engaged to the turning tires/wheels/hubs through the locked Warn hubs. But no engine power is being delivered to the front axles until the front drive shaft is mechanically engaged to the transfer case - which happens when the transfer case is electrically shifted into 4WD - either 4WDH or 4WDL. So you do need to get your transfer case to shift into 4WD via the electrical shift mechanism/motor attached to the transfer case before your 4WD will be functional.
My prior post was an effort to explain that your front drive shaft and front axles are always going to be turning with the Warn hubs locked, whether the transfer case is in 2WD or in 4WD mode. You'll only have 4WD functioning when both the Warn hubs are locked AND when the transfer case is engaged in 4WD. So running with the Warn hubs locked when you don't need 4WD causes unnecessary wear to the U-joints and the splined shaft on the front axles and drive shaft, when you're not utilizing 4WD (running the transfer case in 2WD). It is convenient to always run with the Warn hubs locked, because 4WD is then available simply by electronically shifting the transfer case into 4WD. But leaving the Warn hubs locked when you're not going to be needing 4WD is a waste of engine power and waste of wear and tear on the constantly rotating front drive train.
Old 02-22-2012, 01:00 PM
97 ford beast 97 ford beast is offline
97 ford beast is starting off with a positive reputation.
you now have to manually do it because of the new hubs they wont shift electonicly any more it acually depends if you wired it correctlyi just fixed this in my 7.3 excursion.
Old 08-17-2015, 01:44 PM
Studawg's Avatar
Thread Ender
In that attachment that Payson posted above, can anyone tell me what "S124" is referring to where it breaks off from Fuse 27? I see that controls the Vacuum Pump Motor, which is what Im trying to fix. I have a new pump and I don't think its working. My Fuse 27 was blown and Im trying to figure out what controls the Vac Pump to see if that blew at the same time. Maybe its that S124, but I don't know what that is referring to.
Hub locks Akflyboy Excursion - King of SUVs 5 12-13-2016 01:44 PM
2003 Expedition possible bad 4x4 control module? underdogl3 1997-2006 Expedition & Navigator 5 02-18-2016 07:00 PM
Stuck in 4x4 with hubs locked Daewoo Excursion - King of SUVs 6 12-15-2015 03:47 PM
Low range 2 wheel drive lkbenson 6.7L Power Stroke Diesel 4 06-05-2015 09:52 AM
Need Help With ESOF Big Sky 1999 to 2016 Super Duty 52 09-23-2014 07:23 PM
Tags
2003, 450, 4wd, 97, diagram, diesel, esof, excursion, f150, ford, fuse, problems, ranger, shift, truck, wiring, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
