HPOP Oil change? - Ford Truck Enthusiasts Forums
HPOP Oil change?
Old 02-18-2012, 08:33 PM
pete/ny pete/ny is offline
pete/ny is starting off with a positive reputation.
HPOP Oil change?
Being new to the 7.3 have some questions on the subject of changing the oil in the HPOP.I have never read anything in the Owners manual covering this.Never knew there was a seperate oil resevoir on this unit either.Is there a dipstick to check it and how do you change it and at what intervals? Thanks in advance.
Old 02-18-2012, 08:36 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Your engine oil flows from the oil pump through the HPOP reservoir and ends up back in the pan. No reason to check the oil level unless you're troubleshooting something. Oil flows through there whenever the engine is running.
Old 02-18-2012, 08:56 PM
Thank you
Chris- thanks for the reply.So in other words, this HPOP should be full of oil at all times ?? Why is there a hex plug on it? Do you check the oil level regularly or if the crankcase is full, so is the HPOP?
Old 02-18-2012, 09:06 PM
DISLFVR's Avatar
DISLFVR DISLFVR is offline
Locomotive breath
DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.
It's usually within an inch from the top if you remove the plug.. But no need to check or change it when you do oil changes, it mixes within seconds after start-up.. Only time to check the level is if it's leaking and your having issues.
Old 02-18-2012, 09:16 PM
F350-6's Avatar
Yes, the HPOP reservoir should be full at all times. There is a plug there so you can check the level while trouble shooting LPOP issues, drain back issues, or in case it drains down during extended cranking and no start situations.
I sucked the oil out of my HPOP reservoir one time in the 393,000 miles I have on my engine so far. I sent that oil to Blackstone labs along with a sample of oil that was drained out of my oil pan during a regular oil change. I did it because of all the discussions that came about after that misleading video that showed up on youtube. The lab found no difference in the oil out of my HPOP reservoir and the oil drained from my oil pan.
In my opinion, if you want your engine to last at least 400,000 miles, keep up with your maintenance, but don't waste your time changing the oil in your HPOP reservoir. If you don't believe me and think you have stagnant oil in there, park your truck in a place that you don't mind having an oil spill and remove the plug on the HPOP reservoir. Leave the plug out and start the engine. If it's slow to start, crank it for 30 seconds and then stop. You shouldn't lose more than a few gallons of oil trying this, but you can figure out exactly how much when you re-fill the crank case.
If you don't like the idea of the messy test and you're more of the book learnin type, we can discuss how the engine oil flows up from the LPOP through the HPOP reservoir. From the reservoir it either goes into the oil rails in the heads and is forced through the injectors before returning back to the crankcase, or is dumped back toward the crankcase at the IPR.
The stock 17 degree HPOP is a fixed displacement piston pump that flows 7.2cc's per revolution. The HPOP spins at 85% of the engine speed. So if we idle at 500 rpms (just a hypothetical round number) that means 500 rpms x .85 x 7.22 cc's = 3060cc's pm or per minute. If we do a conversion from 3060 cc's to quarts, that gives us 3.23 quarts per minute.
Now do the math at 2,000 rpm's and you'll understand why there are so many threads talking about not using oil additives because they can cause foaming oil.
With that kind of volume passing through the HPOP reservoir, do you really think it's necessary to change the oil in there?
Old 02-18-2012, 09:20 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
Why yes, yes I do!
Old 02-18-2012, 09:30 PM
F350-6's Avatar
Quote:
Originally Posted by nlemerise View Post
Why yes, yes I do!
Well, I guess it's hard to argue with tin foil hat Bill.
Old 02-18-2012, 11:55 PM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Why yes, yes I do!
That's funny!I'm on rep lock for 24 catch ya later LOL
Old 02-19-2012, 02:53 AM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Quote:
I got him for ya!
Chris, excellent post! Very much the truth and well said Brother!
Old 02-19-2012, 07:19 AM
Chris- Thanks again.I am heeding your advice and leaving it alone.Seems like you are pretty smart on this diesel stuff and if it isn't broke-leave it alone. Pete
Old 02-19-2012, 09:43 AM
DavidE DavidE is offline
DavidE is starting off with a positive reputation.
Recycle used Oil
To protect groundwater that becomes drinking water and runoff water going into fish habitat please do not dump oil anywhwere but recycling pan.
Old 02-19-2012, 04:02 PM
Tailgate77478 Tailgate77478 is offline
Tailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud of
LOL...that tinfoil hat photography majic is awesome!
However, before you go "knocking the HPOP reservoir change," don't forget Jody from DP Tuner has posted here that you should change it out every oil change, and I think a lot of people would respect his opinion. Yeah, it's only about 3/4 of a quart out of 15 quarts. But, why leave 6% old oil in there if you don't have to? It won't kill you to leave it in there (as almost everyone does), but it won't kill you to spend an extra 5 minutes sucking it out either.
If you don't believe me that Jody said it, here ya go (half way down the page, his #5 on the list):
http://www.ford-trucks.com/forums/10...l#post10585299
HPOP Oil Change - After or before engine oil change? sunuvabug 1999 - 2003 7.3L Power Stroke Diesel 14 10-23-2016 09:24 PM
oil change on hpop onebadv2 1999 - 2003 7.3L Power Stroke Diesel 58 01-31-2016 12:47 PM
HPOP Jterr 1999 to 2016 Super Duty 5 12-15-2015 06:54 PM
Stock or Diesel Site HPOP? acf6 6.0L Power Stroke Diesel 13 09-08-2013 11:18 PM
HPOP Oil Level bakerbuilttracks 1999 - 2003 7.3L Power Stroke Diesel 4 03-09-2011 12:50 PM
Tags
2002, 73, 73l, 97, change, changing, diesel, f350, ford, forum, hpop, hybrid, injectors, oil, reservoir, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
