F-250 Power Steering Pump question
I'm not very mechanical but in this economy I'm trying to learn. I have an 86 F-250 Diesel 4x4 automatic. The steering has gotten worse in the last few months, it is very hard to turn to the right in particular and it makes that squeaking high pitched sound like if you turn a wheel all the way to the end.
I'm assuming the power steering pump is going bad, could it be something else causing this?
Thanks.
Thanks.
The seals are probably leaking on the original pump.... I had the same problem. Had to keep filling the pump up like every 2 days. Easy way to fix it is get a new pump. If you aren't very mechanically-inclined then I'd suggest you have a shop swap out the leaky pump with a new one for you.
My steering gear made the truck hard to turn to the right and the pump made noise, so you may have two separate problems like I did. Apparently the gear to get is Redhead ($200+) and the pump to get is Saginaw. I opted for junkyard parts and if they go and I want to spend some money, then maybe I'll reconsider.
Here's a pretty good how-to: https://www.ford-trucks.com/forums/1...placement.html
Good luck!
Dutter
1983 - 2012 Ranger & B-Series
08-28-2011 10:50 PM
dcassidy
09-17-2009 09:11 PM
duck head
12-15-2006 02:10 PM
TNT in Round Rock
1999 to 2016 Super Duty
12-09-2006 03:37 AM
