anybody know rear hub diameter ? - Ford Truck Enthusiasts Forums
Old 02-18-2012, 07:44 PM
Chippenwhales's Avatar
Chippenwhales Chippenwhales is offline
Chippenwhales is starting off with a positive reputation.
trying to figure out the rear hub diameter on the 1993 f350 SRW 4x4, sterling 10.25...want to run hubcentric rims only, dont trust the stub centric type for the weight i carry.
Old 02-18-2012, 11:26 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
From your avatar pic, looks like you still have steel rims...?
Those are perfect for any load, you'll break something else way before the rim or the studs.
Old 02-18-2012, 11:38 PM
IDI guy's Avatar
IDI guy IDI guy is offline
IDI guy is starting off with a positive reputation.
Doesn't the F350 have Dana 70 anyway? Your front wheels will be off the ground and your tires will pop way before you do any damage to the stock steel wheels.
Old 02-18-2012, 11:46 PM
The Dana axles are 1985 and older models F-series only, and all E-series are Dana. 1985+ trucks all have Sterlings axles (except the F450's, Dana 80)
Old 02-19-2012, 12:17 AM
IDI guy's Avatar
85+ 250's and 350's have the same rear axles?
Old 02-19-2012, 12:19 AM
Yes sir! Same axle, same gearing options.
Old 02-19-2012, 12:58 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
I MIGHT BE IN TROUBLE AGAIN , but i don't think that there are any hub centric wheels for these fords with out being custom made !
Old 02-19-2012, 01:41 AM
just wondering--the cost of replacing all 4 tires is so astronomical, i might as well buy 16.5 rims and tires...but i need hubcentric ( like my stock steelies ) for the weight carrying capacity....
Old 02-19-2012, 02:02 AM
cj06's Avatar
I have run duals on them axles with 235-85-16 tires and hauled more weight than are older F600 has from time to time and have never had a b problem with any studs braking ! the studs on these axles are some big ole studs 5/8" i think ! no matter what size they will hold up to what you are going to haul with just a single tire !
Old 02-19-2012, 02:19 AM
Quote:
yeah...i still want to run hubcentric. lets say i got a 4000lb car on the wheel lift...plus the 2500lbs for the wheel lift itself,and assorted equipment.all told, this truck clocks in at 7600lbs+, BEFORE any equipment or car to be towed. so loaded we are looking at right around 14000-16000lbs, or more. driving at 40-45mph. and i accidentaly run that single rear wheel into a 15inch wide by 5inch deep square edged pothole......nope, dont want lugcentric. hubcentric only. theres a reason ford designed them that way...if i cant get a rim in 16.5 with hubcentric fit, then i will stay with the stock steelies. this truck had alcoas and 33 inch mickeys when we bought it, sold them and put on the stockers cause we knew we was gonna carry weight.
Old 02-19-2012, 02:28 AM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
wanna see something cool...i snapped a stud on my RR tire off putting a spare on when i blew a tire....will post pics soon!
Old 02-19-2012, 08:00 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
I believe it's 4.88". At least that's what the accuride catalog claims for the F250 & F350 duallies...
Old 02-19-2012, 08:20 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
i have never hauled heavy with my truck nor anything else for that matter, but if the loads you are hauling are putting your lug studs and rims in question then you NEED to get a heavier duty truck. or lay of the payload. even upgrade to a dully.
Old 02-19-2012, 11:39 PM
Quote:
actually, the total capacity of that 10.25 sterling is supposedly 18000lbs according to a few different websites. so i am within capacity. i just dont want to chance snapping a stud--- when if i carry the weight on the hub ( like it was designed to ) then i wont even have to worry. and these trucks are kinda known for being able to carry/haul WAY more than most people think they can. right now my limit is the tires and then next the brakes !
Old 02-20-2012, 06:53 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
Quote:
Wondering why you want 16.5's? They are getting harder and harder to find. When you do find 16.5's they aren't cheap. I've got a set on a 78' RamCharger. Changed to 3/4 ton axles and 16.5's clear the front calipers. Tires to fit the wheels (10 or 12 inch width-don't remember) are getting tough to find.
4x4 front hubs plumberdale 1999 to 2016 Super Duty 6 11-13-2016 09:01 PM
dana 50 locking hub, need help. cant figure out SSBMX 1999 to 2016 Super Duty 2 06-24-2016 02:58 PM
1967 F250 Camper Special Rear Hub Size Terry1960 1967 - 1972 F-100 & Larger F-Series Trucks 8 04-28-2015 04:28 PM
Dog dish hub cap diameter oft 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-26-2011 03:55 PM
Hub Caps salf100 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-23-2010 08:19 AM
Tags
1994, 1997, 2009, 2011, 94, bore, diameter, f100, f150, f250, f350, ford, hub, rear, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
