Slip-Yoke bump is back after TSB repair what next? - Ford Truck Enthusiasts Forums
Old 02-18-2012, 07:31 PM
Pool Runner's Avatar
Pool Runner Pool Runner is offline
Pool Runner has a very good reputation on FTE.Pool Runner has a very good reputation on FTE.Pool Runner has a very good reputation on FTE.
Had my trucks bump that happens when you come to a stop, it's basically like this you slow down and stop at a light or stop sign or in a parking lot. Truck comes to a complete stop then a 1/2 second later a small clunk that you hear and feel in the driveline.
Anyway, I've got the spec'd truck in my sig... Had the truck fixed for this where they removed a rubber boot covering the driveline splines, greased the area, installed a new boot and called me to come pick it up. Truck drove buttery smooth for about 3-days then the bump & clunk slowly started coming back. Now it is back to where it was before the repair.
I would say it happens 7-10 times of coming to a stop, extremely annoying for a truck with just under 5K miles, repair was done about 1K miles ago. My question to you all is this... is there something else other than the slip-yoke causing this? Do I need to have them replace the entire driveshaft? I thought I recall reading here where a guy had his fixed, then it came back and they replaced the entire shaft or something else.
Old 02-19-2012, 06:35 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Has the dealer driven your truck and actually felt this happening? I'm wondering if they just applied the repair based on the TSB and not from feeling it from behind the wheel.
Old 02-19-2012, 06:39 AM
tharding tharding is offline
tharding is starting off with a positive reputation.
Same problem with my 2010 F-150 Platinum,64k miles. They just did the TSB 10-22-6, where they cleaned and greased the rear driveshaft spline. But the "bump" is still there. It only does it when you come to a slow stop, right before coming to a complete stop the bump hits when it shifts into 1st gear from 2nd. It won't bump if you stop quicker, brake harder.
This is scareing me into buying an extended warranty.
BTY, it would seem, if there was a prob with grease not staying on the driveshaft rear spline, then what about the front spline into the trans?
Old 02-19-2012, 06:41 AM
Ford8502 Ford8502 is offline
Ford8502 is starting off with a positive reputation.
Did they just remove the boot and grease what they could see, or did they do the complete service which requires them to remove the driveline, clean it, and heavily grease the inside and outside splines so all surfaces are covered when slid back together?
Old 02-19-2012, 06:49 AM
tseekins's Avatar
Welcome to FTE! Great first post sir. Keep those excellent ideas coming.
Old 02-19-2012, 07:09 AM
Ford8502
I didn't look over their sholder when they did the work.(my mistake, huh!) lol
I will have to ask about that. And does it have to be a certain spec grease?
I emailed them the TSB, but they said they had already done that. This work being done at a Chrysler dealer.(yeah, every time I leave there, I disenfect myself and the truck.) ;-)
This is a used truck that I just bought last week.
Old 02-19-2012, 09:01 AM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
when you guys come to a stop, try chasing the gears down as you go, and then limit the trans into second so that it cannot shift into 1st.
the "slip-bump" is a bind in the drivetrain that suddenly relases, and that is covered by the TSB.
my 2010 XL will do similar as described, only it is a quick 2-1 downshift as you let off the brake and roll onto the gas. The truck almost always holds 2nd at a stop, then quickly shifts to 1st as you start to move. somtimes it does it seamlessly, sometimes it is quite noticable.
give it a try, if it works, at least you will know if it is the dreaded slip-bump, or the querky 2-1 downshift.
Old 02-19-2012, 11:44 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Good point on the slip-bump and trans shift issue. I've got a couple of Expeditions at work with high mileage that do the same quirky 2-1 downshift. It's very noticeable though.
Old 02-19-2012, 01:25 PM
captaineddie captaineddie is offline
captaineddie is gaining momentum as a positive member of FTE.
Fords have had this problem for at least twenty years. I had a 1991 F150 with the 4.9 straight six that did this, and the dealership greased it for me for the eleven years I owned the truck. There either needs to be a fix for it or a redesigning for the drive train.
Old 02-19-2012, 06:33 PM
meborder's Avatar
Quote:
slip-bump isn't exclusive to ford. I know a few chebbie owners that have been plagued by this issue as well.
i think chebby was even nickle plating the slip yoke, and they still had problems.
i'm guessing it is not an easy problem to fix, there is a lot of pressure on the splines, and quite a bit of movement.
Old 02-19-2012, 10:59 PM
Actually had the same problem with one of my company trucks an '08 Chevy GMT900 2500 HD 6.0L Gasser, we also have an '08 Nissan Frontier Crew Cab, V6 4x4 that even does the same bump-thunk. It happens more frequent though in my F-150 though and it's my favorite truck to date.
Old 02-21-2012, 10:53 PM
fittyford fittyford is offline
fittyford is starting off with a positive reputation.
Slip Yoke thump
The ford TSB repair using blue grease XG-8 did not last for me 2010 f150 extended cab two piece drive shaft.I give up on Ford.I used MERCURY MARINE GREASE with TEFLON (2-4-c ) part nbr 92-802863A .It worked for me.I pulled the rear drive shaft and packed the female slip yoke completely full with marine grease (front drive shaft) then coated male spline with grease (rear drive shaft).I then forced the rear shaft into the female slip yoke result grease flowing out but filling every nook and cranny.You will need a ford cv boot clamp $8.50 and CV boot clamp pliers $9.00 most auto parts stores.It worked for me,no more thump!I cleaned male and female spline with brake clean (no grease residue/must be perfectly clean).Be sure to let dry 10-15minutes to ensure completely dry so grease can adhere properly.This fix calmed my nerves down,and I am once again happy with the best truck made "FORD 150"
Last edited by fittyford; 02-22-2012 at 02:55 PM. Reason: add cleaning information
Old 02-21-2012, 11:32 PM
<TABLE class=ProductDetail border=0 cellSpacing=0><TBODY><TR><TD class=CategoryTrails colSpan=2>Top > Engine Systems > Engine Lubricants > Grease & Applicators > Mercury 2-4-C with Teflon 8 oz. Tube</TD></TR><TR><TD colSpan=2><TABLE cellSpacing=0 width="100%"><TBODY><TR><TD class=ProductNavigation><< Prev Category 3 of 6 Next >> </TD><TD class=ProductNavigation><< Prev Product 10 of 10</TD></TR></TBODY></TABLE></TD></TR><TR><TD class=ProductImage></TD><TD class=ProductDetail>Mercury 2-4-C with Teflon 8 oz. Tube
SKU: 92-802859A 1
PRICE: 6.99
Old 02-22-2012, 11:49 AM
meborder's Avatar
sounds like a good product, and waterproof to boot.
it lists it as "extreme friction" but i cannot find any reference to "extreme pressure"
generally speaking, as i have been told anyway, you want a grease that is rated for "extreme pressure" on the slip yoke.
obviously, you are happy with the performance, so it is worth trying, i would think.
Old 02-22-2012, 12:37 PM
Here's a link for a Suzuki and Toyota site that sells the Ford lube and describes how to use the lube on Toyotas. It's priced similar to the marine lube above. I think the key is getting the parts clean and then adding enough lube to do the job as fittyford said. From the other site:
"When you are hitting the brakes on your Toyota Tacoma, Hilux, 4Runner or Sequoia and there almost seems like someone is hitting you in the rear it most likely is the cause of the drive line or drive shaft splines not lubricated.
This is the best lubricant on the market for driveshaft slip yokes. It has a PTFE base, usually known as Teflon, most of which you see in heim joints or rod ends for great wear-ability. PTFE is also used in high friction applications because it does not easily get washed off when hit with water.
Many Toyota technicians have found this to be the fix to an annoying problem that exists on almost All Toyota vehicles over time. Yes it is a Motorcraft item... but its the best thing for Toyota's! We keep this in stock because we have found that even most Ford dealerships do not...and we offer it at a better cost to you!
Part of what the bottle says:
-Eliminates grunt type noise in driveshaft slip yokes
-Eliminates interior and exterior squeaks
-Good general purpose grease containing (PTFE), for use on plastic, rubber and metal surfaces."
Toyota PTFE Teflon Driveshaft Slip Yoke Grease Lubricant Lube Ford Motorcraft XG-8 (ML1167/31508-42027)
Clunking Sound 1L243 1999 - 2003 7.3L Power Stroke Diesel 2 04-10-2015 05:35 PM
"Clunk" when accelerating from complete stop... DRM2004 2004 - 2008 F150 28 02-21-2013 01:34 PM
BW 1356 woes Robert Vandervennet 1987 - 1996 F150 & Larger F-Series Trucks 5 10-28-2012 03:55 PM
Greased the slip yoke on my 2000 robert_l_ross Excursion - King of SUVs 4 06-19-2011 10:06 PM
Transmission slip-yoke? jimbo beam 1987 - 1996 F150 & Larger F-Series Trucks 1 01-09-2009 09:55 PM
Tags
10226, 150, 2010, 2011, bulliten, company, f150, ford, grease, imput, moter, service, shaft, slip, tech, tsb, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
