Slip-Yoke bump is back after TSB repair what next? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-24-2012, 09:08 AM
Chillman15's Avatar
Chillman15 Chillman15 is offline
Chillman15 is starting off with a positive reputation.
I will have to keep that in mind. Thank you for the suggestion! hopefully I wont have to address this problem ever again!
  #32
Old 05-24-2012, 12:26 PM
tomfiii tomfiii is online now
tomfiii is starting off with a positive reputation.
spring
Old mechanic fix was to put a spring between male and female parts.
  #33
Old 05-24-2012, 02:45 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Quote:
someone else want to knock this one down?
sorry ....
  #34
Old 05-24-2012, 08:31 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
my 2004 F350 did the same thing, i removed the driveshaft and heavly applied Mobil1 grease but my thump didnt go away. I went to the local Ford dealer and baught a tube of blue teflon enriched slip joint grease for six bucks. Cleaned the grease off and packed the slip joint with the blue Ford grease, my truck is now butter smooth and its still going after a year. Id go try the Ford grease, its only six bucks and it works
  #35
Old 06-01-2012, 03:10 PM
ilmo ilmo is offline
ilmo is starting off with a positive reputation.
Quote:
Originally Posted by ilmo View Post
Took mine in to the dealer and they are going to replace the driveshaft. I didn't ask, but I hope this means the entire two pieces and the carrier bearing. The tech had found burrs, but didn't specify the exact location. I have already had the slip yoke greased one time.
Looking forward to a real solution. Keep your fingers crossed.
The dealer finally got me in to get the drive shaft replaced and the slip/bump from the slip yoke are gone. Hope this is the final solution, but time will tell.
They replaced the two piece drive shaft and the carrier bearing.
  #36
Old 06-02-2012, 12:19 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Is this issue happening with the 2012 models?
  #37
Old 06-03-2012, 12:30 PM
Pool Runner's Avatar
Pool Runner Pool Runner is offline
Pool Runner has a very good reputation on FTE.Pool Runner has a very good reputation on FTE.Pool Runner has a very good reputation on FTE.
Quote:
When my truck was in for repair , they gave me a loaner '12 Super Crew, short box, 4x4, Ecoboost. That truck had the slip-yoke bump too. Only had 1300 miles in it as I recall. Also had a single drive-shaft where my 2wd has a two piece one.
  #38
Old 02-08-2013, 10:59 PM
Cw28 Cw28 is offline
Cw28 is starting off with a positive reputation.
I just took my 2010 in for the same problem and the dealer called me saying i had "transmission failure" thankfully I purchased the extended warranty. They're replacing the clutch plates and a few other components. Hopefully this solves it. A bit extreme to what I thought was going to be an easy fix. I take great care of my truck, so pretty shocked the tranny went out @ 80k.
  #39
Old 02-12-2013, 10:07 AM
Jetmec1333 Jetmec1333 is offline
Jetmec1333 is starting off with a positive reputation.
Is this an issue with 2013 models?
I have the slip-yoke bump on my 2010 FX2 and I was wondering if there are any reported issueson this with the 2013 model F150s
  #40
Old 02-20-2013, 06:55 PM
johngraves2's Avatar
johngraves2 johngraves2 is offline
johngraves2 is starting off with a positive reputation.
I just got the 2013 FX4 f-150 and I have this issue. I am very upset because it doesn't even have 1K miles on it yet. Should I take this back to the dealership asap or what?
  #41
Old 02-20-2013, 09:23 PM
Yes sir, I would suggest you take it in. It is a known issue for at least a couple years now. Nothing new and your service dept. shouldn't act surprised when you tell them about it. Several TSBs on this very issue.
A simple grease fitting or two on the yoke would seem to be a very simple and logical solution, but it is beyond me why Ford cannot do this. Unless, of course, I am totally missing something.
Mine is starting to do it again and this will be the third time with 32K. The last time a new drive shaft was installed and it has lasted the longest. The first time I had it done was around 7K.
  #42
Old 02-20-2013, 10:20 PM
Thanks! Is this something that they will perform for free or no?
If not I will take it back to the place i bought it from and really complain to get them to perform it for free. Other wise there is a ford dealer a lot closer to me.
  #43
Old 02-21-2013, 05:52 PM
Charlie Bravo Charlie Bravo is offline
Charlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to all
BMW makes a grease for the driveshaft splines for their motorcycles. The shop owner called it a high impact grease. Greasing the splines on those motorcycles is a yearly maintenance thing. If you neglect that it's only a matter of time til you can kiss your shaft goodbye. CB
  #44
Old 02-22-2013, 03:42 PM
This is something that is covered under warranty and should cost you nothing other than the time you have to spend at the dealer.
Note: If they say they "cannot duplicate" the problem, request that you have some one take a ride with you and point it out to them. I have had to do this before, because I will not accept an answer of "cannot duplicate."
Good luck, should be a very simple fix.
  #45
Old 03-08-2013, 09:10 AM
hookd's Avatar
hookd hookd is offline
hookd is starting off with a positive reputation.
I had my 09 in for a rear pinion seal earlier this week and had them do the slip bump TSB at the same time. $100 p&l for the seal and $80 p&l for the TSB and she is smooth as silk. He said the splines still had grease on them and couldn't understand how it would be having an issue so we will see how long it lasts. It was the local mechanic that did it because I cannot stand our local Ford Stealer. If it starts again I will try the marine grease and heater hose so we we will see.
Scary clunk in drivetrain DBreedlove 1999 to 2016 Super Duty 24 04-07-2014 11:49 AM
"Clunk" when accelerating from complete stop... DRM2004 2004 - 2008 F150 28 02-21-2013 02:34 PM
BW 1356 woes Robert Vandervennet 1987 - 1996 F150 & Larger F-Series Trucks 5 10-28-2012 04:55 PM
Driving an EcoBoost rental from the dealer right now.. Pool Runner 2009 - 2014 F150 47 06-12-2012 12:11 PM
What happened to my guage screen on he dash? Pool Runner 2009 - 2014 F150 5 04-16-2012 05:16 PM
Tags
10226, 150, 2010, 2011, bulliten, company, f150, ford, grease, imput, moter, service, shaft, slip, tech, tsb, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
