torque spec on brake calipers
Old 02-18-2012, 05:12 PM
IDI guy's Avatar
IDI guy
IDI guy is offline
Does any one know the torque spec on the brake caliper bolts. I need the spec on the two motnt bolts on each side of the rear and the four mount bolts on each side of the front. It is on 06 f150 4x4 5.4l.
Thanks
Jeff
Old 02-18-2012, 06:40 PM
shorebird's Avatar
shorebird
shorebird is offline
This needs to be asked in the correct forum.
https://www.ford-trucks.com/forums/forum28/
This is the '04-'08 F-150 forum.
Old 02-18-2012, 07:18 PM
Coskid's Avatar
Coskid
Coskid is offline
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
He is asking for the spec on an 06 F150 4x4 5.4L.
IDI guy's Avatar
IDI guy
IDI guy is offline
Sorry I forgot to put model of truck I fixed it.
Coskid's Avatar
Coskid
Coskid is offline
Thanks
Jeff
I will dig around and see if I can find it for you.
Old 02-18-2012, 07:23 PM
Coskid's Avatar
Coskid
Coskid is offline
OK looks like the front bolts are to be torqued to 47 lbs and the Rear bolts to 22 lbs.
Let us know if we can help with anything else.
Old 02-18-2012, 07:37 PM
shorebird's Avatar
shorebird
Thank you I responded to the unedited OP where the only reference to a vehicle that I saw was the '92 F-250 by your avatar.
Old 02-18-2012, 07:44 PM
IDI guy's Avatar
IDI guy
IDI guy is offline
Hey thanks a lot guys! Got it.
Jeff
Rocks58
1999 to 2016 Super Duty
05-27-2019 10:29 AM
Whitey Ford
2004 - 2008 F150
10-24-2015 07:17 AM
Macrosill
07-25-2015 06:22 AM
Macrosill
07-17-2015 06:25 AM
rcorcich
06-25-2009 08:26 PM
Quick Reply: torque spec on brake calipers
