Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 02-18-2012, 01:06 PM
samthemountainman samthemountainman is offline
Garage is empty, add now
samthemountainman is starting off with a positive reputation.
2004 F150 engine timing problem?
I have a 2004 F150 xl, 5.4L, 4x4. Was taking it up a high mountain pass the other day and engine started running bad, check gauges came on the warnings in the dash, and noticed no oil pressure. Turned it off and restarted gauges went to normal, but motor ran like it was out of time. Had codes checked and these came up, PO345, PO054, PO325, PO340, and P2270. All of those were pending but the PO345. Changed out both Camshaft Positioning Sensors and checked wiring to them. I have the O2 sensors on order but pickup is still running like it is out of time and dies when you come to a stop with a rough idle. Any suggestions all will be appreciated.
  #2 (permalink)
Old 02-18-2012, 01:32 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed is gaining momentum as a positive member of FTE.70f100longbed is gaining momentum as a positive member of FTE.
Have you checked for sludge build-up? Look in the oil fill hole and see if there is any sludge. The phasers need at least 25psi oil pressure to operate properly.
__________________
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
  #3 (permalink)
Old 02-18-2012, 02:46 PM
Checked oil in valve train and looks good, oil has been changed on this pick up at regular times.
Tags
04, 150, 2004, 54, code, diagnose, engine, f150, ford, issue, issues, po340, po345, problem, timimg, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
