Fuel Tank Heater? - Ford Truck Enthusiasts Forums
Fuel Tank Heater?
Old 02-17-2012, 09:41 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Fuel Tank Heater?
Ok, as I was laying down trying to sleep for about an hour the only thing I think is trucks and what can I do to all 4 that I have. Then I realized that I have never seen or heard of a fuel tank heater pad like they have on RV's for the clear/gray/black water tanks to keep from freezing. Do they make one like that that you can just stick on and plug into the wall to keep your diesel from gelling? Or be able to tie it in with the block heater so when you plug your block heater in your fuel tank would turn on also. Of course only the nothern/cold states would benfit from this but it makes sense to me. Has anybody heard of this being done and would it be worth it?
Old 02-17-2012, 09:49 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Uhh...Living in CA, thought never crossed my mind, however, a friend of mine, told me that, his buddy was told, if you dont have a block heater, is to get a big pan of coal, light ur up, let it get the white hot ashes, then shove it under your truck...
Old 02-17-2012, 11:06 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
The problem is when you start driving, the wind against the tank will cool it enough to gel again. You can install an ArticFox fuel heater but they work off coolant so you would have to keep the engine running or park inside at night.
Old 02-17-2012, 11:24 PM
portsample's Avatar
portsample portsample is offline
portsample is gaining momentum as a positive member of FTE.portsample is gaining momentum as a positive member of FTE.
Fuel that is sold at latitudes where this is a problem is formulated to eliminate or minimize this. I lived in Fairbanks for over ten years and never heard of anyone heating a fuel tank (other than propane tanks). While there is an amazing variety of heating devices for cars, I knew old timers who lived out in the bush with no electricity that would cover the front section of their car or truck with rectangular sleeping bags, or quilts at night and would be able to start in the morning in spite of temperatures below minus 40 degrees F.
Old 02-17-2012, 11:49 PM
Pitcrw6's Avatar
I'm not sure how much air is directly hitting the tank for it to gell up but i'm just thinking for when your truck has been sitting overnight in the cold and you have your block heater plugged in you could have this on as well to ungell any disesel in the tank. I'm not sure what temp diesel starts to gell at but I'm sure its diff from #2 diesel to bio 20% and up to 100%. Im just thinking out of the box.
Old 02-18-2012, 10:20 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
Originally Posted by timmyboy76 View Post
...a friend of mine, told me that, his buddy was told, if you dont have a block heater, is to get a big pan of coal, light ur up, let it get the white hot ashes, then shove it under your truck...
You first....
Old 02-18-2012, 11:38 AM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I do not have a pad but they are available through alternative energy vendors (vo) .
Visit Forums and you will find some info in the SVO section, maybe the biodiesel too.
Similar to this site, there are vendors who are members.
Old 02-18-2012, 02:26 PM
PaulDH PaulDH is offline
PaulDH is gaining momentum as a positive member of FTE.
Solution = Use of Winter Grade Fuel
Never heard of anyone heating fuel in their fuel tanks. You'd still have the potential for the fuel to gel in the fuel lines anywhere between the fuel tank and the fuel injectors. Start driving the truck down the road in cold temperatures, and the wind chill on those fuel lines would be terrific, quickly chilling the fuel down to near ambient outdoor temperatures. I believe the only reliable prevention is to ensure the fuel in the vehicle is gel-proofed down to the anticipated/potential minimum temperatures. Otherwise a person is just asking for headaches.
Old 02-18-2012, 04:06 PM
portsample's Avatar
I think these guys are talking about biodiesel gelling in cool weather, in which case I'd be looking at ways to keep my fuel above ambient as well...
Old 02-18-2012, 04:15 PM
Ahhhhh, that could be. For fuel that thickens at 30F, there may be some benefit. And in those milder temperatures, heating the fuel in the tank may keep it warm enough to make it to the injectors prior to re-gelling.
Old 02-18-2012, 05:16 PM
portsample's Avatar
Roger that. The best solution would be figuring out what in the mix is thickening, and then adding something to break that molecule down into smaller H-Cs that don't gel. If that is not possible, I do think that keeping the fuel above ambient would be the only other solution. I'd think about spray foaming the tank after applying a silicone heat patch to the tank. It may not be possible to do this if the foam doesn't stick to the plastic fuel tanks...fabricating one out of aluminum might solve this, and a clever welder could build one with clearance to allow for a good foam coat on all sides...something that might not be possible with a stock plastic tank. Plugging the heat patch in would then warm the fuel with the insulation helping to keep it that way.
Old 02-18-2012, 08:09 PM
dn29626's Avatar
Quote:
Originally Posted by PaulDH View Post
...Never heard of anyone heating fuel in their fuel tanks...driving the truck down the road in cold temperatures, and the wind chill on those fuel lines would be terrific, quickly chilling the fuel down...
I do not heat my tank but i do heat my fuel lines and have them insulated. No wind chill for me.
As to the topic here, fuel tank heaters are available.
Old 02-18-2012, 09:24 PM
HD Rider's Avatar
Old 02-19-2012, 12:04 AM
Pitcrw6's Avatar
Quote:
Originally Posted by HD Rider View Post
Well there ya go, my question has been answered. Thanks Paul
How To: Flushing with Restore and Restore Plus 99ExpyProblems 6.0L Power Stroke Diesel 18 05-17-2016 01:29 PM
Setting up transmission, oil pan, an battery heaters - Tugly get in here!! 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 12 04-29-2013 09:15 AM
Oil and Transmission Pan Heaters 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 7 03-13-2013 02:46 PM
Block Heater installed in 07 4x4 Expedition Newton007 2007 - 2014 Expedition & Navigator 0 07-28-2007 12:02 AM
Engine coolant tank heater? Twin Tritons 6.0L Power Stroke Diesel 11 11-14-2006 01:55 PM
Tags
1987, diesel, ford, heater, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
