Engine rebuild kit for 390 - Ford Truck Enthusiasts Forums
Old 02-17-2012, 09:41 PM
fatee98 fatee98 is offline
fatee98 is starting off with a positive reputation.
I've got a '73 highboy with a worn out 390 coupled to a 4 speed tranny. I'm looking for advice and insight into what would be a good and economical rebuild kit for this motor.
It would be nice to get some more horsepower out of it also but I know that would probably throw the "economical" aspect of it out the window. I want it to be dependable but still have decent horsepower and torque.
Any ideas??
Thanks.
Old 02-17-2012, 09:51 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Sure!
How about 445 cubic inches of bowtie-crushing FE power? Talk to Barry Rabotnik at Survival: http://www.survivalmotorsports.com/
Old 02-17-2012, 11:21 PM
Highboy74's Avatar
Highboy74 Highboy74 is offline
Highboy74 is starting off with a positive reputation.
Don't waist your time, drop a 460 in and call it a day. Cheaper, more power, and easier to find parts.
Old 02-18-2012, 08:50 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Survival has a complete 390 rebuild kit for $700. Not too shabby.
Don't believe that just dropping in any 460 will automatically be cheaper and more powerful. In stock form all the 70s and 80s engines are kind of doggy with all the emission regulations put on them. If you want 400hp or less then rebuild the 390. If you want more than that, then the 460 swap starts to become the better option $$wise the further past 400hp you go.
Old 02-19-2012, 10:14 PM
Jeremy, yes that's what I'm looking for. Not looking to makes gobs of power just want something that's gonna be reliable with a decent amount of power on tap.
I was thinking the same thing about the Survival rebuild kit.
Autolite 2150 - economizer cover Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-06-2016 01:42 PM
Horsepower and torque for 390? Tylersgrave 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-15-2011 05:55 PM
Horsepower, torque & compression ratio from 1976 Motor manual for various engines. Blown 331 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-24-2009 04:57 PM
Carburetor help 66f-100 1961 - 1966 F-100 & Larger F-Series Trucks 17 06-03-2008 01:14 AM
Figuring horsepower luv2getnailed Performance & General Engine Building 11 09-13-2001 07:01 PM
Tags
1977, 390, 67, code, engine, engines, explorer, ford, kit, motor, rebuild, rebuilding, rebulding, v8, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
