Spindle Nut Question.
Did brakes on my F250 today, when pulling the spindle nuts (nut/washer/nut) I noticed the locator pin on the inner nut that locks into the washer was broken on both sides. This may have happened on removal.
Is there any harm in runing the inner nut without the locator pin? I plan on eventually geting a new set of spindle nuts to replace the ones I have now.
Without the pin you cant preload the bearing and then then torque the outer nut properly.
http://warn.iwebcat.com/imgVD/WAR/32722A2-pn32721.pdf
nothercrash
17
02-01-2013 06:13 PM
jim henderson
03-23-2010 07:44 PM
MuchToMyDelight
10-29-2003 10:49 PM
