Oil and Trans Temps while towing
So today I helped a buddy tow his new (to him) 65 Impala over the Pacheco Pass.
Truck:
2000 Excursion, V10 4x4, 106k on the odometer, 87 octane gas. Stock radiators and coolers - no aftermarket coolers added.
Trailer:
U Haul transporter dual axle trailer + 65 Impala.
Conditions:
The pass is 1300ft max altitude and the outside temps were in the mid 50s to about 63. We were loaded Eastbound only, and I shut the OD down on the inclines to prevent it from hunting for gears.
I'd like to know if my temps were appropriate. I have a GlowShift oil temp gauge...sending unit is in the sandwich adapter at the oil filter. I have another GlowShift trans temp gauge...sending unit is in the test port on the driver side of the trans.
Here is a quick shot of the peak readings on both gauges:
That is about 209-210 oil temp, 150 trans temp.
So...how do those numbers look?
Truck:
Trailer:
Conditions:
Engine oil temp should run right around the coolant temp depending on where your sensor is located. Since your's is a sandwich, it is reading the oil coming out of the pan, which has had time to disperse any higher temps equally. I think coolant temps should run around 210 (but now sure). Use your ultra-gauge and watch for any gap between your engine oil temp being much higher than your coolant temp.
Trans temp looks really good but I seem to remember the 2000s have a smaller trans cooler and you may want to upgrade that for the Sacramento 100 degree days.
