Got my floors and Cab supports replaced
Harley,
Yeah I know he flanged it, but you have to be under it to know. I am building a good 20 footer, so that kind of stuff doesn't matter to me. I have a couple more inside projects before I start the save for the outside. I have to get inner and outer front fenders, and a radiator support so, I figure I need at least 2 grand for the parts and the work to get them all in. I will undercoat all the fenders, and the support.
Looks really nice. And flanging it shows he has the tools and cares about his work. Replacing those front cab mounts without taking the cab off is a bear.
Ive been there.
I wish I would have used the DC front cab supports. I thought about cutting the ones I got from LMC off, and using the other ones, but its just too much work at this point.
Ive been there.
Looks GREAT!
I couldn't find anyone who would do it around here without taking the cab off, and by the time I bought the materials, it was cheaper for me to buy a new cab with good floors/mounts... I figured since I'd have to remove the cab anyway- Replacing it was just going to be easier.
I believe I would prefer the added stiffness gained by flanging vs a butt joint at a floor connection. Also, in order to properly make a butt joint disappear it would take a continuous weld bead that was hammer welded. In my mind, based on the location, it would be inferior to the flanged joint, since it would have less strength and would be more costly due to more intense labor.
Greg: I dont even think Id want to try a butt joint right there. Trying to hold the pan in place, and get it welded in the right place, not gonna happen, not without adding a catch to hold it in place while welding, then taking it off when done. I just did a lap joint on mine, welded the top and bottom, ground it down, called it good enough. Cant see it unless your under the truck, and the carpet will cover the inside.
I do butt joints reguraly on floor pans. It is best with a body saw with a NARROW blade or cut off wheel with narrow wheel.just trin to about 3/4 " from size.anchor panel,cut around tack every so often,(1"-1 1/2") as cutting.it is not a big deal.short tacks that eventually are one keep heat down. Grind it,if u did it well just a small bit of finishing putty aand wala. Both sides like it never happened,and no pocket to trap moisture like a flange...but that is just me.I am probably a perfectionist.sorry for the long post
Sound proofing
Now that you got it all opened up, you might want to consider putting some sound proofing in the cab. These things are noisy and you can really cut the road noise without much cost.
Various manufacturers make pads with sticky backs that you just apply to a clean surface.
Good work on the rust abatement. I had to do a ton as well.
Here's the link to my 65: www.photobucket.com/HolmesFordF100
Last edited by 1965F100(3onthetree); 02-20-2012 at 12:11 PM. Reason: Added link to Album
