2011/2012 super duty with BOSS PlOW FRAME PICTURES
Looking for pictures of the super duty with the Boss plow frame mount on the truck to see how well hidden the mount will be and how people hooked up the wire connections to the truck. Did a search and found nothing so hopefully people out there have pictures of the BOSS plow mounts. Also wondering if anybody used an up fitter switch instead of the little switch BOSS gives you to go from truck headlights to plow headlights.
I saw one last week on a newer gasser......it looked just like mine the only difference between his and mine was the grill. You still will see the same amount of frame below the bumper cut through and around the black thing sticking down (air dam or whatever its called) and it has to be the same height on all trucks.
The wire connections are all hooked up the same with the connections at the drivers side grill. Some installers do not like mounts and some do. On my old 6.0 the connections just tucked in nicely behind the bumper. On my 08 I have them mounted in the bumper cutout.
I thought about connecting the lights to the upfitter switch. Thats as far as it went...sorry.
Wrecker
12-28-2002 10:34 PM
