Chirping noise from Rear axle when accelerating
Hey all,
Got a problem but not sure what it is. First off, I have a 2001 Ford Ranger Edge, RWD, automatic trans, 3.0 V6.
Recently I started getting a chirping noise when I'm driving. Initially thought it was the drive belt but after driving some with my window open, I was able to determine that it was coming from the rear axle (or something in that vicinity).
I only get the noise when I'm accelerating or pushing the gas pedal a decent amount, and for some odd reason the last 10 feet or so when braking to a stop (the latter may be a separate problem or just brake squeal but not certain). But it is primarily when I'm on the gas pedal. It's a chirp-chirp-chirp kinda thing, and the faster I'm going the faster the chirping.
It does NOT do it when I'm coasting (regardless of my speed), idling, or pushing the gas while in park/stationary. The only time I can avoid the noise is when I'm already up to speed, and barely touching the gas pedal (even then I'll still get it sometimes).
Anyone have any ideas? TIA
Ah ok.
Yeah, I found a few other threads on here that cited the U-joint as the culprit, but those people's descriptions of their problem didn't include anything about only getting that noise when pressing the gas, so I figured I might have a different problem.
I've done a lot of repairs myself, but I admit I know basically nothing about the drivetrain.
might want to describe the steps in pinion seal replacement before he goes and just rips the nut off and then doesn't have the right amount of preload on the bearings. I would check the diff vent to be sure its not clogged before assuming the seal is bad. A clogged vent will cause it to leak.
Idk if its the u joint
Ik this thread is old af but if anyone is still around to knowlege me id appreciate it. I just replaced my u joint a month ago because it grenaded 2 of the bearings but i still get the exact same chirp op described. Is there any chance it could be the dif or would ut be more likley a brake issue. 2005 3.0 auto rwd extended cab if that helps
jbourne84
06-28-2017 12:38 AM
calnix
03-23-2004 12:57 PM
