Front Sway Bar for 57-60 F100, will it work? - Ford Truck Enthusiasts Forums
Old 02-17-2012, 11:32 AM
black58's Avatar
black58 black58 is offline
black58 is starting off with a positive reputation.
Found this picture on the Slick 60's site. This guy mounted a 67-72 front sway bar on his early 60's F100.
Here's a pic of my front suspension. Notice how the shocks are mounted compared to the previous picture.
Do you think it would work if I were to drill holes in the lower shock mounts to serve as the lower mount for end links? Have any of you successfully mounted a sway bar on your truck?
Old 02-17-2012, 07:24 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
The pic of your front end didn't come thru. I think it should be fine to mount off the shock backets. It seems to me that the closer you are towards the outside of the truck the better.
Old 02-17-2012, 08:43 PM
black58's Avatar
Quote:
Really?? I see it fine.
Old 02-18-2012, 02:02 AM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
This is the only picture showing up.
I dont see why it wouldnt work on your truck, frame width is the same and the front axles are the same design so you should be able to make it work.
Scott
Old 02-18-2012, 07:16 AM
black58's Avatar
That's really odd, I see both pictures and can blow them both up fine, I'll see what I can do. At any rate, I'll try to find one at a junk yard and see if I can install it.
FYI, the axles are slightly different, that's why I'm asking if anyone has done it before. The later axle has the lower shock mount in the axle out toward the wheel. Ours have the lower shock mount just about right where the picture above shows the end link connected. I'm worried that the end link and shock will try to occupy the same space
Old 02-18-2012, 07:22 AM
black58's Avatar
How's that?
Old 02-18-2012, 04:21 PM
spurredon's Avatar
Now I can see it fine.
I also see what you mean about double occupancy! Can you heat the sway bar and open it up a bit and put tabs just outside the shock brackets?
Old 02-18-2012, 08:58 PM
tbirdscott's Avatar
I think heating he sway bar could mess up the temper of the steel pretty well.
How about mounting the sway bar at the rear of the axle? looks like you might have enough clearance to get it in front of the transmission. Kinda tough to tell without measurements. Then you can mount it to the axle the same as in the sample pic.
Scott
On second look the steering may get in the way mounting it from the rear...
OE Sway Bar End Link Replacement with Pics Y2KW57 1999 to 2016 Super Duty 25 06-08-2016 07:35 PM
Rough country 6" lift sway bar drop bracket mounting wrdabney 1987 - 1996 F150 & Larger F-Series Trucks 0 04-24-2016 06:00 PM
'88 F150 - Coil Spring/Shock/Sway Bar Info MR KROGOTH 1987 - 1996 F150 & Larger F-Series Trucks 19 02-28-2016 02:16 PM
OEM F+R Sway Bar, 3rd times a charm. Imports2Domestics 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-07-2013 10:09 AM
Sway Bar Question tasboj 1967 - 1972 F-100 & Larger F-Series Trucks 26 07-07-2012 10:51 PM
Tags
1999, 5760, 89, bar, core, diagram, f100, f150, f250, ford, front, rear, shocks, support, suspension, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
