6.2L mpg update?
#226
The way I always heard it " there is no replacement for displacement" or " there is no substitute for cubic inches"
I think my next truck will be a 6.2 when I finally get tired of my 7.3. I browse this sub forum occasionally to keep informed and must admit, the 6.2l forum is one of the most boring forums on FTE. You guys just don't have anything to talk about.
Any 6.2 common problems? - Ford Powerstroke Diesel Forum
#227
I took the camper off this week for the first time since 500 miles, truck has 8,500 on it now. Had to run from northern ca to San Diego last night, truck was empty, 14.2 MPG according to the lie-o-meter. Best number I've ever seen. Truck has 4.30 gears and very little of that was at the speed limit.
-Joe
-Joe
#228
#229
#230
A good tail wind can make that happen
#231
I have a 2011 F-350 single wheel four door short box with 3:73 have 10,000 miles on it. Some times with a heavy load sometimes not sometimes no load ,sometimes no trailer. I run hills, flat mostly 65 to 85 mph not a lot of in town. The truck over all the conditions has averaged 12.4 miles to the gallon and I am very pleased with that I had a 2005 6.0 diesel that was set up the same way as this truck and drove it the same way and in the 18,000 miles I drove it is averaged 9.7 miles to the gallon that is why I sold it. I will never own another diesel pickup. If I need a diesel to pull a big load I will get the semi out.
#233
We just wrapped up an 11 day Mid-West and Great Plains trip from GA through TN, KY, IL, WI, MN, ND, SD, IA, NE, MO, KY, TN and then back to GA. 4157 total miles driven. That left me with just under 14,000 total miles on the odometer.
Average mpg was 13.68 computer and 13.44 hand calculated. For the trip I had added a Softopper bed cover which I believe hurt fuel economy by 1-1.5 mpg. Without it I usually get 14.7-15.3 at Interstate speeds. Speeds averaged 70-80 mph. With myself, family, and gear we had about 1000lbs in total payload.
I did try E85 for one tank and that was enough for me as we only got 9.84 mpg for that tank.
#234
#235
#236
After a couple years with my 6.2 I've noticed that 70 mph is about the tipping point. I can drive on a 65mph highway and get almost 18 if the wind/terrain isn't hurting it, but you get up over 70 mph and it starts to drop off in a hurry. Real tough to get more than about 14.5 at 77 mph cruising on the interstate. After two years of mixed driving (highway, a lot around town, I pull loaded trailers a few times a week for business, couple LONG unloaded interstate trips, etc) I'm getting just over 13 mpg overall. I'll take that all day long. Big improvement over my old 460 or V10.
#237
Denny
#238
#240
Regarding mileage, remember that air resistance increases as a square of vehicle speed. So at some point, mileage will start to drop off quickly. Sounds like 70 is your "magic" number.
