6.2L mpg update? - Page 5 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
6.2L mpg update?
  #61
Old 08-10-2012, 10:32 PM
butch50 butch50 is offline
butch50 is starting off with a positive reputation.
Quote:
Originally Posted by wyo2track View Post
Butch50 - How you doing on mileage empty at highway speeds of 65 to 70? I see 2000Silverbullet averaging around 10.2 at speeds alittle more than that. I've got alot of wind in my area too. Thanks.
I really can't say as I don't drive my truck much empty on the road in fact I have had my truck almost 2 years and have just over 13000 miles on it. There was one time I got 17 MPG on the road but I was driving slower but there were still hills in it and some stop and go but I was really taking it easy on the go pedal
  #62
Old 08-15-2012, 05:40 PM
RAPR's Avatar
RAPR RAPR is offline
RAPR is starting off with a positive reputation.
Just drove a couple hundred miles back from Houston TX, mostly interstate driving with speeds between 70-75mph and got 13.8mpg. The truck was empty.
  #63
Old 10-12-2012, 12:41 PM
unyalli's Avatar
unyalli unyalli is offline
unyalli is starting off with a positive reputation.
Here is my first test of brand new 2012 6.2L F250 CC LB. This was round trip Cheyenne to south Denver and back. 65mph except in the city. I hand calculated as well and it's slightly off. I put 15.03 gallons in it which is 16.6 mpg. I filled at the same pump facing the same direction before leaving and on return.
  #64
Old 10-12-2012, 07:02 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Liftime average on the 6.2 is 14 over 20,000miles.
Lifetime average for the 5.4 is 15 over 26000miled
Epty the 5.4 is 1000lbs lighter plus the manual trans probably is most of the difference.
With the trailer the 6.2 gets alot better mpg and does a bit better on the hills. I do much prefer towing with a manual; and usually tow with the 5.4 unless i need the crew cab
  #65
Old 10-12-2012, 11:27 PM
kewldaddydave kewldaddydave is offline
kewldaddydave is starting off with a positive reputation.
Type of fuel
Does it matter what type of fuel? I have run only E85 since I purchased my 2012 F250XLT FX4 6.2L in July. I now have about 2700 miles on it and only avg. about 10mpg. Is it really good to switch between fuels of 87 and E85?
  #66
Old 10-13-2012, 09:31 AM
Super08's Avatar
Super08 Super08 is offline
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
E85 has less energy in it and gets less mpg than regular gas.
  #67
Old 10-14-2012, 08:28 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
Quote:
Start using 87 and you will see about 2 mpg increase. It may take 1 or 2 tanks to get all the E85 out. IMO the cost savings per gallon don't match up to the mpg decrease of the E85, so I just stick with the 87 and only use Shell or Mobil.
  #68
Old 10-15-2012, 01:10 AM
Quote:
Sounds good to me. I will try that. Thanks for the input.
  #69
Old 10-16-2012, 10:04 AM
windrider127 windrider127 is offline
windrider127 is starting off with a positive reputation.
Also the manual states not to run more than 3 tanks of E85 in a row.
  #70
Old 10-24-2012, 09:46 AM
unyalli's Avatar
Thought I would update this. 1300 miles now and looks like daily average is going to be comfortably in the 14's. This is 2 mpg better than my 2005 5.4 F150 2wd when it was stock and new. I'm happy.
  #71
Old 11-07-2012, 11:38 PM
PowerFish PowerFish is offline
PowerFish is starting off with a positive reputation.
MPG
Just picked up my new to me 2011 F-250 CC Lariat FX4 w/45k miles. Drove 367 miles in my 2008 GMC Sierra 1500 w/DOD to pick it up and averaged 16.9mpg in the GMC on the way there. Picked up the F-250 and rolled out with a full tank of gas from Branson, MO to Omaha, NE and averaged 15.3 on the computer with 87. Did not do the math on return.
Mixed driving all week so far with 13.3mpg on 89 E10
  #72
Old 11-20-2012, 02:22 PM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
618 mile trip including driving around Williston and Minot for a day and a half and averaged 14.8mpg hand caculated. Highway speed was 70mph and half of the trip into a headwind.
  #73
Old 12-26-2012, 04:09 PM
FordGuy250 FordGuy250 is offline
FordGuy250 is starting off with a positive reputation.
I have a quad cab with 3.73 gears been getting 12.8 city driving. Have seen numbers as high as 16.5 at 65mph. Took off all the exhaust up to first resinator then piped it to rear wheel, seems to me increased 2-3 mpg.
  #74
Old 01-01-2013, 01:44 AM
newapple newapple is offline
newapple is starting off with a positive reputation.
2012 crew 4x4 6 ft bed 18" wheels bed cover. Local around town12.0 mpg highway15 mpg
373 gears 9,000 miles synthetic oil
  #75
Old 03-25-2013, 12:10 PM
4x4editor 4x4editor is offline
4x4editor is starting off with a positive reputation.
6.2L mpg
I just finished testing the same truck in XLT trim for ProPickup magazine. Unloaded. 15.4mpg @70mph over 200 mile run on I-10 flat interstate. No wind. Ideal weather. Pump figures--not onboard computer. 13.2mpg during 150 miles of city driving with light to moderate stop-and-go.
2017 6.2 MPG question levimorris85 Texas Chapter 3 01-30-2017 12:40 PM
Not new but back! grpark20 New Member Introductions 2 12-15-2016 11:45 AM
Update on 6.2 MPG buono26 2017 Super Duty 7 11-27-2016 08:56 AM
Poor mileage jwdenney2 2004 - 2008 F150 39 06-23-2015 07:19 AM
Official Mileage report Thread? 96sherm 6.2L V8 52 05-14-2011 07:17 AM
Tags
150, 2011, 2012, 250, 292bhds, 62, 62l, duty, f250, f350, ford, gas, mileage, mpg, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
