6.4l Power loss - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4l Power loss
Old 02-16-2012, 07:32 PM
KAGC KAGC is offline
KAGC is starting off with a positive reputation.
6.4l Power loss
My 08 6.4l starts, idles fine but has no power when I depress pedal. I drained water separater, replaced fuel filters and all fluids are at the proper levels. When going up a hill near home plumes of white smoke and no power. Any ideas of the problem? Thanks in advance.
Old 02-16-2012, 07:52 PM
LJC's Avatar
LJC LJC is offline
LJC is starting off with a positive reputation.
Any codes that you know off?
Old 02-16-2012, 08:02 PM
Quote:
Not yet. I'm going to mechanic tomorrow to try. I'm just trying to get some ideas now but I'll post codes tomorrow.
Old 02-17-2012, 07:47 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Injectors or HPFP are my thoughts.
Any coolant loss?
Perhaps EGR valve or coolers are the issue.
Old 02-17-2012, 07:55 AM
Quote:
Any coolant loss?
Yes I've noticed small amount of coolant loss.
Old 02-17-2012, 08:21 AM
senix's Avatar
Be sure to mention that. It points to EGR coolers or the valve. They will need to pressure test the system.
Sometimes moisture buildup in the cac will cause the white smoke as well but you have power loss too so that points to other causes.
What is your fuel ecomony and frequecy of regens?
Old 02-17-2012, 08:49 AM
12mpg and nothing out of ordinary on regen. Except other day when I had trouble climbing hill. I've seen people write about limp mode. Well thats wat comes to mind when trying to get home that day. It goes but at own speed...Truck is straight stock dually 4x4 , 4.10 with138K.
6.4 L turbo diesel...yay or nay? Larry Bell 1999 to 2016 Super Duty 6 06-20-2016 09:40 AM
making decisions...... huckster 1999 to 2016 Super Duty 5 06-12-2015 02:02 PM
Good Reading on your 6.4 Bounds-Electric 6.4L Power Stroke Diesel 14 01-23-2012 05:57 PM
08 F-350 6.4L Low Power Acarboni 6.4L Power Stroke Diesel 6 09-04-2011 07:11 PM
best programer for 2010 6.4L power stroke? bulverde bill 6.4L Power Stroke Diesel 23 04-11-2011 02:26 PM
Tags
08, 64, 64l, connector, coolant, ford, loss, mississippi, moisture, power, powered, public, radio, turbo, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
