351 Windsor conversion - Ford Truck Enthusiasts Forums
Old 02-16-2012, 03:52 PM
5oakseric's Avatar
5oakseric 5oakseric is offline
5oakseric is starting off with a positive reputation.
I bought an 89 F150. The previous owner swapped the motor. It has a 93 351Windsor and a C6 transmission. It was such a shade-tree swap they didn't get much of the vacuum stuff hooked up. Being a 4 yr difference I don't know what goes where. It runs rough and is only getting 11 MPG. I'm contemplating just dumping all the efi stuff and converting to.
Carb. I like simple when comes to cars. It doesn't need to pass inspection so how tough would this be? Thank you in advance for your help.
Old 02-16-2012, 04:03 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
You will need a 351w Carb intake and carb, Kickdown bar for the C6, throttle cable for the carb. You will also need a fuel pressure regulator with a return, to tune down to fuel pressure to the carb to 7psi; or you will need to disable the factory fuel pump, remove the high pressure fuel pump, install a electronic 7 psi pump into the fuel line, and crimp the return fuel line.
Think about this though: Carb & EFI get the same mpg (when working properly), EFI has 20 more torque, Carb is cold natured.
Biggest benefit of carb is you can run any head/cam/intake combo.
I will post again if I think of something else.
Old 02-16-2012, 04:46 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
The 351 in my truck only gets 8mpg's...I'd kill to get 11. HOWEVER, I like carbs. Easy to work on, and highly modifiable. Opt for a 4 barrel carb because you can. otherwise SC is right on the money. If I were you I would just get the pressure regulator instead of taking the rest of the pumps out and putting in another electric pump.
The downfall of course is that the EFI isn't as cold blooded, but it's not too hard of a process.
Old 02-16-2012, 05:38 PM
SCRebel's Avatar
I agree with the 4bbl. I like Holley, and I like the 650 cfm with a stock motor. And a Good Edelbrock aluminum performer (operation range idle - 5500 rpm) intake.
I have a EFI 351w:
I get 14-16 mpg, depending on how I drive. I am running on a fresh rebuild, completely stock; with no cat, smog, or EGR.
Old 02-17-2012, 04:55 PM
5oakseric's Avatar
If I understand correctly the 351 is a 302 block? Will any manifold off a 302 fit? I'm gonna need to get most parts from the junkyard. Which motors can I ask for parts from?
Old 02-17-2012, 05:14 PM
SCRebel's Avatar
Quote:
NO, the 351w is NOT the 302 block. The 351w and 302 have the same bore size, but the 351w block is 1/2 taller, because the 351w has a 1/2 longer stroke. So the 351w has its own block.
Now, the 302 and 351w does use alot of the same stuff. I think the manifold can work, I am not real sure. But they do use the same piston, water pump, belt system, timing cover, valve covers, and motor mounts.
To be on the safe side I would try and get exhaust manifolds off of a 351w. The 351w intake manifold is larger than the 302.
Old 02-17-2012, 06:30 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
351w is wider than a 302... so the 302 intake will not work..
Old 02-19-2012, 12:47 AM
5oakseric's Avatar
ok, on to the next step
Thanks guys, now I start rounding up parts. What year model 351w's will or will not have a compatable intake manifold when shopping boneyards? Thank you again
Old 02-19-2012, 12:59 PM
SCRebel's Avatar
Any 351w intake manifold from 1977 (ish)-1987 will work. 351w intakes from 69-76 had more bolt holes.
Defiantly check out 80-86 & 87 body style F-series and bronco. Most 351w came with the 4 bbl intake. (however some had the 2 bbl intake) If you find that body style bronco or F-series (again 1980-1986, then 1987) with the 4 bbl 351w HO then you can take the intake, carb, distributor, electronic ignition box and wiring, and throttle cable.
The 351w became EFI in 1988.
1977 351 Windsor Submarriner 1947 and Older Ford Trucks 1 02-10-2014 06:52 PM
351 Windsor swap from 351M questions defiantoutlaw 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-10-2013 06:58 PM
351 windsor union bubba 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-18-2011 02:41 AM
351 windsor in place of modified crzycrazycarl 1973 - 1979 F-100 & Larger F-Series Trucks 39 06-04-2010 10:51 PM
351M for a 351 Windsor namdorf 1973 - 1979 F-100 & Larger F-Series Trucks 19 04-14-2008 05:02 PM
Tags
1994, 351, 351w, 79, 89, conversion, efi, ford, fuel, intake, pressure, propane, regulator, sale, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
