2005 6.0 exhaust residue question.
Old 02-16-2012, 02:06 PM
TheMuffinKing's Avatar
TheMuffinKing
TheMuffinKing is offline
Hello, new to the forums here, I had a question regarding residue I noticed in my exhaust pipe.
Yesterday I had a 4'' silverlight exhaust installed on my 2005 6.0 F350. After the half hour drive back to my apartment, I inspected the exhaust and noticed a thick black/brown sludge in my exhaust pipe. I took note of this and went to inspect it again after the truck had cooled down for about an hour and noticed that the sludge had solidified into a hard plastic like mass.
Coolant levels were unchanged, oil was good too. I just had my fluids serviced at Brien Ford up here in Everett and they didn't bring up anything before this.
Do you have any ideas on what this might be?
Old 02-16-2012, 03:00 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,097 Likes on 997 Posts
It didn't get hot enough to burn it off..... 30 min of diesel running WILL build up sludge.....Go drive it at highway speed for an hour....or put it in Tow/Haul and it'll run at a higher RPM (until you get over 50 or so). Or - don't go looking at the inside of that exhaust pipe! LOL
Old 02-16-2012, 03:31 PM
Ian123's Avatar
Ian123
Ian123 is offline
It might just be soot build-up, although after I installed my new exhaust it took about 3 or 4 days for that to happen.
Old 02-16-2012, 05:04 PM
goosehunta's Avatar
goosehunta
goosehunta is offline
i belive that when they manufacture the pipes they use a oil to lube things up during the process and also to keep it from rusting or whatever. this oil is inside the pipes and as you run the truck and soot starts collectiong on the oil thats in the pipes. it would look like what you said. when i put on my MBRP system i saw the same thing but went away after a week or so.
i could be wrong on this but this is what i read on here when i first saw mine do it.
Old 02-17-2012, 02:40 AM
TheMuffinKing
Thanks for the replies, I'm sure its what you guys mentioned. I'll keep an eye on things and post if anything changes.
crusherII
1999 to 2016 Super Duty
07-06-2009 09:12 AM
pdiesel
Exhaust Systems
12-11-2008 08:48 AM
05f250fx4
16
05-09-2006 06:33 PM
ptc54
03-12-2005 02:05 AM
astrotaz
Exhaust Systems
03-20-2004 05:30 PM
Quick Reply: 2005 6.0 exhaust residue question.
