53-56 F100 Frame Height
For what it's worth, we've got a frame from a 54 panel in our driveway, along with the stock drivetrain and tires.
If anyone needs any frame msmts let me know. It's not often you have a frame sitting in your carport without a body on it!
As you all know, the panel frame is a pickup frame with a pair of short rear channel extensions bolted on the rear tips of the frame. I would imagine any long bed pickup used the same extensions.
If anyone wants a locked up 239 Yblock, 3spd trans or rear end for free, I'm the man to see.
'fenders... here is the substitute for a thousand words, it should keep this post to well under that. I am not crazy about Brett's suggestion for there are so many places to measure from.... "Measure from the bottom of the frame rail to the top of the leaf spring pack right by the axle housing spring pad mounting surface." I am not sure I know how to get an accurate measurement there without an extraordinary amount of tedium.
I measured where the kickup in the frame occurs and getting tape, camera and my big squash under the truck is tedious. The tape touches the frame and axle housing. The measurement to the top of the axle housing appears to be five inches. Is this helpful in any way? If not, you have this lovely picture to refer to.... Best. Himmelberg
Peter has it right on the nose. When you are messing with your suspension, the only variable that matters as far as ride height goes is the distance from the axle to the frame when you are done with your mods. Tire and wheel choices will, of course, also affect ride height but they can be considered separately.
I couldn't find it in a search, but some time ago we put together a short calculation that would let you figure out your frame height with a few simple measurements. Essentially, it boiled down to what Peter measured.
One of the shortest and most to-the-point posts lately - great post Peter! I really appreciate someone who can cut to the essence of the issue.
Peter
Thanks for the PIC, that is the measurement I was looking for. Now I am confused. It appears you are lower than I am with stock springs. As you have already mentioned, your springs may be fatigued. I agree.
Also, the cow painting in your gallery is very nice. I was thinking of buying it for RMF for Christmas. How much you want for it with shipping to Ottawa? Don't cut your self short on the price. You need some spring money.
'fenders... last weekend I had a half yard of dirt dumped in the bed for use in Mrs. H's lavender bed. You should have seen how low that made it. Am looking for someplace that re-arches springs.
Mural is NFS. Belongs to the Library now. Cost of a copy for our Canadian brother is negligible... cost of an 80' x 20' canvas is probably prohibitive.
Thanks for the kind words, George.
Peter
Peter
Peter,
Can you re-arch springs that are significantly fatigued? I believe yours probably are. I'm asking, I don't know. And very nice mural. Looked like quite a project. Do you paint a lot?
George
We better throw some kudos to Brett here. Peter took a picture of what Brett actually stated a couple days ago on this thread.
Everyone,
Still looking for anyone else with stock suspension who would take the axle to frame measurement. I don't think Peter's truck represents anything close to stock height anymore.
George
Everyone,
'fenders, you're right! Brett, you get the cookie for the right idea.
Peter, shame on you for ... for ... for doing something. I'm so confused. Time for my medication.
'fenders, I can give you the measurement on Earl but I don't think it will help much given the lack of engine, transmission, cab, front body, and bed. Besides, Earl is an F-250.
"fenders, I can give you the measurement on Earl but I don't think it will help much given the lack of engine, transmission, cab, front body, and bed. Besides, Earl is an F-250."
George
I know you would help me out if you could. F250 measurement wouldn't be of any value this time. I am really wondering if I even have stock springs at this point. They are in awful good shape, only five leaves and similar to Peter's in ride height (8 leaf stock set I assume),that are probably tired out. Peter' truck must not have that sky high stock stance either, because mine is nowhere near stock height.
This isn't going anywhere. We are constantly advising guys here to pull a couple three leaves. I just thought if would be interesting to know how much drop occurs from this trick. It's not really going to be of any consequence if I don't find out.
George
Originally posted by fatfenders
... This isn't going anywhere. We are constantly advising guys here to pull a couple three leaves. I just thought if would be interesting to know how much drop occurs from this trick. It's not really going to be of any consequence if I don't find out.
I'll tell you what. I can try to find the nominal rear axle load in my shop manual tonight for my F-250 and then scrounge up an appropriate scale. I'll load up the rear of my frame on one side to the nominal weight and then do the spring leaf removal thing I outlined above. That would give the drop you get by removing leaves under nominal load for an F-250. Let me know if you think that would help you out. If not, I'll let somebody who's going to do it anyway on their F-100 or F-1 do the before and after measurements.
It seems as though you have settled this issue but I spent so much time trying to actually get a photo that I thought I would post it anyway...
I can't believe how hard it was to hold a camera, postion a light, look through a view finder and try to get a decent picture at the same time. And I thought getting some rusted bolts off was hard.
Just addin my two cents..
Kevin
Kevin
#30
Kevin,
Thanks, its far from settled. Your measurement is what I expected to see. You are a little over 2 inches higher than I am. That makes a whole lot more sense after removal of three leaves from mine. I'll verify a couple more trucks but I expect 8+ inches in stock form. I bet they were 10+ new.
RMF
I grabbed a couple ratchet straps and winched my 9 in axle tubes up agin the frame last night. That suit ya? I'll pick up a set of them loboy billet caster wheels for the running boards at PF like you mentioned offline.
RMF
