F150 back spacing questions
on
Factory wheels have zero offset which means the 8" version has 4" backspacing, the 7.5" wheel has 3.75" backspacing, and the 7" wheel has 3.5" backspacing. To retain clearance on the radius arm you want to use no more than 4" backspacing and maybe even a little less which means the 10" wheel you'll need for those 33's will have -1" to -1.5" offset.
I concur. I run my 33x12.50-15's on a set of 15x10" wheels with 3.625" backspacing (-1.375" offset). No rubbing issues here.
This is depending how bad they rub with just the stock rims
on
The general dislike of spacers comes from a history of failures with these things that is most likely due to a weak product that also probably wasn't installed correctly.. incorrect torque. I'm of the same opinion that I wouldn't use spacers under any circumstances, and in this case they won't be needed anyway because those tires are simply too big for the stock wheels, you need 10" rims.
The copper website said reccomended wheel 8-10"wide mine are 7.5.
Im going to run them on my factory wheels untill I find aftermarket ones I like and have the cash for them.
My current tires are worn out so I need new tires and don't want to get something I dont want for tires to hold me over till I find rims, the girlfriend would shoot me lol
Cooper Tire & Rubber Company - Light Truck
Looking at the two 33x12.50-15 offerings that I see on their site (Discoverer S/T and STT), both recommend a rim width of 8.5"-11". If you're insistent on sticking with your stock wheels, I'd highly recommend looking at a 33x10.50-15. It would be much safer, not to mention look far better.
MerCrew66
12-20-2003 05:52 PM
CBSuperduty
07-20-2002 06:31 AM
