Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-16-2012, 01:19 PM
mbarrad mbarrad is offline
1951 Ford F-1
mbarrad is starting off with a positive reputation.
New condensor for 12 volt conversion
I'm converting my 51 to 12 volt and have most of the parts. Do I need to change my condenser? Technician at Macks Trucks says I don't. I'm not so sure about the advice given. Let me know if my concerns are warranted. Thanks.
  #2 (permalink)
Old 02-16-2012, 01:23 PM
raytasch raytasch is offline
1956 Ford F-350
My Garage
raytasch is gaining momentum as a positive member of FTE.raytasch is gaining momentum as a positive member of FTE.
I've converted a few Ford tractors from six to twelve volts and have never worried about points or condenser. Never had any early failures of the points. However, your coil polarity should be changed.
__________________
Fords in the Stable
1956 F350 DRW with hydraulic dump
2007 F150 supercab
1973 F250 Camper Special
1955 Ford 850 restored
  #3 (permalink)
Old 02-16-2012, 01:37 PM
1951 Ford F-1
I'm adding a ballast, and will install a 12 v ignition. I just want to be safe and not fry anything I have to go back and pay for.
  #4 (permalink)
Old 02-16-2012, 02:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
1952 Ford F-Series Pickup
ALBUQ F-1 has a very good reputation on FTE.ALBUQ F-1 has a very good reputation on FTE.ALBUQ F-1 has a very good reputation on FTE.ALBUQ F-1 has a very good reputation on FTE.
If the condenser is an electrolytic type (and I think they are) they are polarity sensitive. Couldn't hurt to swap to a 12v type. Why not go "all the way" and go to electronic ignition?!
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
Other projects/vehicles: '86 Porsche 944; '91 H-D FXRS
  #5 (permalink)
Old 02-16-2012, 02:36 PM
Doc's Avatar
Doc Doc is online now
1949 Ford F-Series Pickup
My Garage
Doc has a good reputation on FTE.Doc has a good reputation on FTE.
mbarrad, You're new here. We need to see pics of your truck. It's a "requirement".
__________________
Shane
1949 F1, Original, 8BA
1950 F1, 302, C6 (in a lot of pieces)
1950 F5
1997 F150 XLT, 4.6L
2008 F250 XLT, 6.4L Powerstroke
  #6 (permalink)
Old 02-16-2012, 02:46 PM
1951 Ford F-1
Quote:
Lol! If I can get her started this weekend, I'll move her out of the garage and take some pics. She's a beautiful girl!
  #7 (permalink)
Old 02-16-2012, 04:04 PM
old_dan's Avatar
old_dan old_dan is offline
1952 Ford F-100
old_dan is gaining momentum as a positive member of FTE.
Hello and welcome to the forum. I'm still looking for those pics!!!
Condensors are one of those products that break down over time. For the cost, I'd throw a new one in there.
Dan
  #8 (permalink)
Old 02-16-2012, 05:04 PM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
New condensors are a crap shoot with so much coming off-shore. The old ones are more reliable - run yours until it fails, then keep a spare or two in the glovebox.
Ross, I'm not sure about that - I run my original on 12V neg grnd and have for 10+ years with no hiccups from the polarity change.
As far as voltage goes, your inline ceramic resistor drops the voltage to the same as the original 6V system. The points only see about 4.5V
  #9 (permalink)
Old 02-22-2012, 04:11 PM
okiemagman okiemagman is offline
okiemagman is starting off with a positive reputation.
been building magnetos and dist for 40 yr and never changed pts or cond for 6 to 12v.
if you don't want to use resistor, buy a 12v coil with internal resistor. it will say on case
-no external resistor required.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
