E99 F350 psd FUEL PUMP TRIP RESET BUTTON? - Ford Truck Enthusiasts Forums
Old 02-16-2012, 11:23 AM
MauleOne MauleOne is offline
MauleOne is starting off with a positive reputation.
I just noticed that there is a sticker under the hood saying that my truck is equipped with a fuel reset button.
Where is this located? I thought I had been all over this truck and I have not see a reset button.
Thanks
Old 02-16-2012, 11:59 AM
429 f-100's Avatar
429 f-100 429 f-100 is offline
429 f-100 has a good reputation on FTE.429 f-100 has a good reputation on FTE.
right side (pass) kick panel below glove box.
Old 02-16-2012, 01:13 PM
Reset Button
Thanks, I had thought that diesels didn't have reset buttons. That is why I was surprised to see the sticker saying there was one.
I will not be home to look at my truck for two more weeks. I the reset behind the kick panel? Do you have to remove it to access the button?
Thanks for the response.
Old 02-16-2012, 01:43 PM
429 f-100's Avatar
no you can reach it thru the top of panel
Old 02-16-2012, 03:16 PM
Reset
Thanks, I appreciate your info.
Old 02-16-2012, 03:20 PM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
I have also used the fuel reset button as a kill switch. Say you want to leave your Ford car or truck somewhere you don't want it stolen. You go and hit or kick the kick panel pretty hard it will trip the sensor and you will feel the button pop up.
And it is also a good way to make sure the fuel reset sensor is working correctly. I have seen where if you hit a bump or tap it lightly it will go off. I have also seen where you can hit it with a hammer and it not go off. That is not safe!! And I have also seen people that were not to bright just bypass them. Now that would just be STUPID!! But stupid people do stupid things! Sorry for running on at the mouth or should I say keyboard.
Old 02-17-2012, 06:04 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Quote:
I have never thought of using it for that. You just have to hope the person trying to steal your ride dosent know about it.
Old 02-17-2012, 10:25 AM
Reset
I wonder how many no start problems have been caused by the reset button?
low fuel message silverbullet6oh 6.0L Power Stroke Diesel 8 11-04-2016 07:30 PM
Fuel mileage reset Gousetis 1999 - 2003 7.3L Power Stroke Diesel 5 10-21-2016 11:09 AM
fuel problem rwmurr18 Air Intakes, Air Filters & Ram Air 0 04-16-2015 12:01 AM
Fuel reset Vinford 1987 - 1996 F150 & Larger F-Series Trucks 15 03-14-2012 08:47 AM
89 f-250 computer reset button? gthbryce 1987 - 1996 F150 & Larger F-Series Trucks 5 05-26-2009 03:54 PM
Tags
2000, 2008, 99, button, diesel, f250, f350, ford, fuel, kill, located, location, pump, reset, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
