High pressure oil leak - Ford Truck Enthusiasts Forums
Old 02-16-2012, 11:06 AM
jerkypants's Avatar
jerkypants jerkypants is offline
jerkypants is starting off with a positive reputation.
Hi all,
My truck has a high pressure oil leak. Ford wants 200 more to tell where it is.
Fix it myself or ford?
Any roughs on cost?
Easy or hard to fix...depending?
Old 02-16-2012, 11:34 AM
jerkypants's Avatar
Sorry
2005 Ford F350 superduty lariat fx4 6.0ptd
Old 02-16-2012, 01:05 PM
jerkypants's Avatar
I haven't been able to find a repair thread on here, did I miss it? In the bible?
Old 02-16-2012, 01:17 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Some guys here do it themselves. There are threads if you search, or I'm sure someone will be along with links.
I can tell you that to do it right, the HPO pump has to come out, and both valve covers have to come off. You tell me if that is a hard job. I don't have the kind of time this would take, so mine is in the shop right now for the same issue.
Ford quoted me "about" $2,500 to do the pump fitting and standpipes on both sides. They didn't get the job.
Old 02-16-2012, 01:29 PM
jerkypants's Avatar
I am beside myself right now, I NEED this truck. I have zero faith in Ford Dealerships. The guy I originally brought it to couldn't figure it out, so he brought it to ford to diagnose (don't ask, I am trying to remain calm) This is going to put me under.
Does anyone on here know someone or want to do this job, I am in New Hampshire and will drive a good distance, out of state even, to have it done right. Let me know how much, I'll bring it out and sleep right in the truck if need be.
Old 02-16-2012, 02:37 PM
bpounds's Avatar
2 bit Californian
Take a look at this thread, in particular Bismic's post #50. This test is used to tell you if the STC fitting is leaking, or the left or right standpipes/dummy plugs is leaking. If you can't swing the whole job, maybe you can get by with finding the particular leak and just fixing that. IMO you would just be postponing repairs of leaks at the other points, but you gotta do what you gotta do.
http://www.ford-trucks.com/forums/87...condition.html
Old 02-16-2012, 02:55 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
How do you find Bismic's post # 50?????
Old 02-16-2012, 03:21 PM
bpounds's Avatar
2 bit Californian
Quote:
Aw hell, forgot the link. Here it is again.
Old 02-16-2012, 04:25 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Post in your areas chapter Im shure somebody there would be willing to help ya out
Theres a Great Bunch of Guys on here
Just saw you already did post there Im shure someone would be willing to lend a hand
Old 02-16-2012, 05:03 PM
jerkypants's Avatar
Thank you guys.
Ford wants to do an air test on it, is that the next step, recommended?
He says it will take a couple hrs so roughly two hundred
I will check out threads now Thnx bismic.
Old 02-16-2012, 05:15 PM
jerkypants's Avatar
My bad, thanks goes to Bpounds, i checked out the thread and it seems the air test is the one. Thanks again.
Old 02-16-2012, 05:36 PM
bpounds's Avatar
2 bit Californian
Hey, it was bismic's info, so thank him first, and I thank him too.
Apparently the air test was over the head of the dealership tech who wanted to work on my truck. All I got was a $460 screwing and no solution. I beat feet out of there.
Old 02-16-2012, 05:45 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
cost will run between 500 and 1600 depending on what they find.
Old 02-16-2012, 05:51 PM
BLADE35's Avatar
Quote:
Bill is your truck not running very good???
That would be tough for me to swallow a 460.00 Bill with No Answer or repair
Old 02-16-2012, 06:48 PM
jerkypants's Avatar
Hey all, thanks very much.
Fixed 3 Oil Leaks and I'm Still Getting a Puddle! brian42 1999 - 2003 7.3L Power Stroke Diesel 16 02-06-2017 10:05 PM
2006 6.0L High Pressure Oil Pump & Oil Cooler Jmags 1999 to 2016 Super Duty 0 10-09-2015 06:08 PM
High Pressure Oil Rail Plug Leak rhodester 1999 - 2003 7.3L Power Stroke Diesel 2 04-07-2014 10:46 AM
High Pressure Oil System Air Test got2befast 6.0L Power Stroke Diesel 2 09-08-2011 04:43 PM
please help, oil leaking on dr side exhaust bigtuna Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-16-2011 09:27 AM
Tags
2005, 2006, 60, apparently, cost, cylinder, diesel, f250, ford, head, high, leak, leek, oil, pressure, repair, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
